Question about Samsung GTB7722
Not boot i switch on my phone but my phone not start and automatic restart i not seen my menu chart
    New Friend:
Update your software
Posted on Apr 23, 2014
My nokia3110c automatically switch off.
Check out this link....many kinds of solutions are provided,one of which should work for u...I suggest that u should start from the bottom of the page.
http://discussions.europe.nokia.com/t5/Hardware-Codes-and-Operator/Nokia-3110c-Automatically-restarting/m-p/186824
Mar 04, 2010 | Nokia 3110 Cellular Phone
Have a problem with start button
Im telling the solution step by step.It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically.
Try this Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months. During these time u can1
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime. but remember below
DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
Jan 14, 2010 | Nokia 3110 Cellular Phone
SAmsung behold turns on and restarts on its own will. Cannot open text messages either
Not sure why it happens, but my behold would start up and then turn off, start up and then turn off, cycling over and over. I checked internet and no one had an answer. Finally tried this and it seemed to work. When the behold finally gets to the first screen (with widgets, phone, ph.book, web, and menu on the bottom of screen) I pushed on the touchscreen menu button. I only had a few seconds before it shuts down and restarts. The menu screen popped up and I went to the "settings" and then "reset settings". It asks for a password (I used 12345), and then confirm password. This will reset your phone, but you will also lose info. or pics on your phone. Phone then did an automatic restart and my phone was back working. I was then able to restore my phonebook #'s because tmobile has an automatic phonebook backup. I hope this helps anyone with the same problem I had. Makes me angry that when I called tmobile they said no one has called with this issue yet I have found many people with the same problem. Obviously some type of glitch that seems to have an easy fix.
Oct 23, 2009 | Samsung Behold Cell Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
months.During these time u can
but remember below DONTs
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Nokia 5800 restarts automatically
try factory reset
go to menu>applications>file manager>backup>options>backup now
this step is intended for content backup, if you don't care to lose your personal info skip it
backup done?
1.first way to apply factory settings: go to menu>settings>phone>phone mgmt.>factory settings>yes
2.another way to apply factory settings:(three finger salute)
now switch off your 5800
while it's off press and hold these three buttons at the same time send(green button) + end(the red button) + camera button(found on the side)
while you're pressing these 3 buttons switch on your phone and hold on to the 3 keys until the hands video is infront of you
the phone then asks for date and so...
tell me if the problem persists and try to clarify it further ahead
i own a 5800 and may be i can be of help
May 02, 2009 | Nokia 5800 XpressMusic Smartphone
Automatically restart mobile sgh j210.
your mobile is virous effected . So you can go to the mobile hardware point and solve it .
Mar 06, 2009 | Cell Phones
Motherboard
There may be automatic restart on in your bios menu. You can access your bios menu by pressing F8 during boot time........... And turn off automatic restart under (hardware) menu...
G.G.
Jan 17, 2009 | Intel D101GGC Motherboard
HAVE PROBLEM
weel I suggest you select a main sim on sim menu. Put your simcard in the left side if you have dual sim slot then open the cellphone, go to menu and select sim switch, then select the main switch. it will automatically restart your cellphone. after that you wait and see good signal bar and your operator logo what ever it is. now its ok. hope it will help you......
Mar 08, 2008 | Nokia N95 Cellular Phone
Restart
this should do the trick...press star, call button(the green one), three, and power button all together while powering up your phone..press them until formatting comes out then you release them..note: don't release buttons until formatting does not appear....try and try until you succeed
Jan 26, 2008 | Nokia 6600
Motorola L7 automatic restart problem
just try flash your phone.it could be work
Nov 20, 2007 | Cell Phones
Samsung GTB7722 Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
