We live in Indore, MP. I bought this monitor around 10 years ago, but recently two easily correctable issues arrived, 1. Colors are not balanced. Sometime Red, whereas sometime blue color takeovers the screen. I think its a general issue of CRT. 2. Switch-On button of this monitor has become kinda loose. We have to push it many times to switch on/off the monitor. I am in dire need to quick and proper help. Hoping for quick and positive response. Thanks, Vineet Agrawal +91-7709083330 [email protected]
SOURCE: Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
SOURCE: Monitor color dominated by blue; Green and red colors fade away as yellow and black
probly just the chord connectin from your pc to the screen. just buy a new chord.
SOURCE: monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
SOURCE: Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
SOURCE: samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
