Question about Konica Minolta Office Equipment & Supplies
Apontando um erro na parte interna onde faca o toner box
Como resolver isso
  • Konica Minolta Master
  • 6,161 Answers
Replace the toner box
Posted on Dec 30, 2015
  • 1566 Answers
SOURCE: error LSU
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Posted on Feb 09, 2010
mishrajk21
  • 202 Answers
SOURCE: Não Consigo acessar Serviço de
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Posted on Jul 30, 2010
  • 44 Answers
SOURCE: como vou resolver o erro
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
Posted on Sep 06, 2010
Joed911
  • 4338 Answers
SOURCE: codigo de erro 3807 como
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Posted on Feb 25, 2011
SOURCE: laser aficio 2045 (erro322)
ola ha a possibilidade de voce desmontar a LD INIT e limpar o LED do laser e os espelhos que ficam dentro do laser.
e um pouco trabalhoso mas da certo pois o toner derrama dentro do laser e ele nao consegue mais sincronizar.
precisa retirar 6 soldas das tres pernas dos 2 leds e retirar os parafusos.
Posted on Nov 21, 2011
COMO RESOLVER ,POIS O MONITOR NAO LIGA?
Oi Anonymous, Verifique a ficha n?o est? solto no monitor eo computador .... e se nada solto em seguida, O link abaixo ? um v?deo do YouTube mostrando como corrigir tela preta, tamb?m h? v?deos para o lado direito do link que voc? pode considerar a pena olhar, bem como, infelizmente, o link est? em Ingl?s ..... espero que isso ajude ... .CHEERS ..
How to FIX Windows 10 8 7 Black Screen of ***** With Cursor After Login...
Apr 27, 2016 | Computers & Internet
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
Apr 25, 2011 | Gestetner DSm745 Black and White Copier
Ola gostaria muito do manual do audi A4 modelo 2000. Pois o que eu achei e em ingles! Tambem gostaria de solucionar um problema no meu audi. Toda vez que piso no freio ele apita, faz um barulho de...
Acho que posso, o que voc? menciona ? o som do "grito" no freio quando o pedal. Poderia ser alguma sujeira na pastilhas de freio or're provavelmente j? passou e est?o se deteriorando outros componentes do sistema.
Sugiro remover os freios e revis?o, tomar vantagem de dar um ambiente limpo e mudar o que precisa ser mudado. Desculpem o texto, mas utilizar um tradutor para isso.
Mar 09, 2011 | 2000 Audi A4
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Mar 01, 2011 | Ricoh Aficio MP 161 Black and White Copier
Boa noite estou descarregando o aparelho mas esta dando erro na transmissa digite enter, mas nao sai disto preciso descarregar ja troquei a bateria qual a solucao?:
Boa noite
Eu tenho um igual e de vez em quando acontece-me o mesmo, como consigo resolver a situa??o, ? precionar a ficha RJ enquanto o PDT est? a transmitir para o PC.
Se pretender tocar mais ideias o meu mail:arlindopolicarpo@hotmail.com
Jan 16, 2011 | Symbol PDT 3100
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
further
Jul 29, 2010 | HP Designjet T610 InkJet Printer
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
