Question about Technics SA-AX530 Receiver
I have a technics amplifier SU G75
IF YOU PLAY THE AMP BELOW 10 ITS PLAYS, ONCE YOU TURN UP THE VOLUME AMP SHUTS DOWN AND ERROR MESSAGE ON AMP DISPLAY READS ''''OVER LOAD''''
PRODUCT INFOMRATION IS NOT IN LIST
INFOR MATION I HAVE IS SU G75PPI-K
SERIAL NUMBER OD5DD38319
  • Audio Service Clinic Aug 08, 2015
    You are playing the amp too long and too loud. It is going into overlosd in an attempt to cool off before the amp is destroyed.
  • Anonymous Sep 04, 2017
    Make sure that the fan is running on bass levels. If not, open top cover, press on clips ·, on fan, remove it and clean AND resolder and tin contacts, fan and chassis to ensure fan contacts..set amp to stereo, and bass max..fan should kick on every low freq. passage..
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Posted on Apr 01, 2010
Technics SU-G75 owners manual download
http://www.manualslib.com/manual/926367/Technics-Su-G75.html?page=2#manual Technics SU G75 Service Manual Page 2
Sep 23, 2015 | Technics SU-G75 Amplifier
Want to download Technics SU-G75 service manual
Technics will not give it to you. Gotta pay the piper!
Did you try to google it - might get lucky - but don't hold your breath.
Sep 21, 2015 | Technics SU-G75 Amplifier
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
No sound from stereo
Greetings
the power module is damaged and the components ... as you described, resistors burned and other components are over heated .
you need a service technician if you are still hanging on your baby :)
unless you are a technician .i will be glad to send you send you schematic.
i cannot post it as(PDF).
Dec 29, 2013 | Technics SU-G75 Amplifier
My technics amp SU-G75 keeps shutting off and reads OVERLOAD when played over the volume of -40 to -35. I kept playing around and it works fine when the bass dial is on half, but more bass shuts it off. I...
some amps are made more for low ohm loads (bass) and some are made for high impedence loads (mids/highs) and it seems you are asking too much from your amp.
Mar 05, 2013 | Audio Players & Recorders
I have a technics su-g75 amplifier, this system hasn't been hooked up for a few years but seems to be in excellent condition. It plays and seems to work great. I don't know whether this is a problem or...
Yes the unit will get fairly hot. If you can keep turning it up at some point the fan should kick in, if it doesn't then it need looking into further.
Apr 23, 2011 | Technics SC-DV290 System
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Amp not working properly.............
Mke sure that the tape monitor switch is turned off.
Dan
Apr 09, 2008 | Audio Players & Recorders
Technics SA-AX530 Receiver Logo
1,662 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
