Question about Gateway M Computers & Internet
I dropped my gateway laptop and now when I turn it on all the lights and fan come on but screen is black,
    Novelist:
  • 188 Answers
With the laptop powered on, press f8 repeatedly or until screen resumes normal display.
Posted on Apr 14, 2014
SOURCE: black screen on gateway 450sx4 laptop
Inverter board. Promise.
Posted on Mar 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: Gateway laptop screen is black?
This could have several causes, including malware installed on your system, but is frequently the result of some kind of hardware driver conflict. Have you recently installed any new hardware or software to your system? If so, disconnect it and try again.
The black screen is an indication that the windows os is not booting onto the system. If you have the recovery console installed, or have the cds, you can run the recovery console to troubleshoot or repair your installation of windows. This procedure is different for xp or vista, so we need to know what os you're on, as well as any error messages you see when it fails to boot.
To begin with, try tapping F8 as it boots up and see it you can get into the OS options screen, then choose Last Known good configuration to boot windows.
Here's a great article to help you troubleshoot the situation, then let us know how it goes and what comes up..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
shahabdun
  • 249 Answers
SOURCE: My gateway laptop gives me a black screen when I
Check the screen button.
Posted on Jul 16, 2009
budmrtn
  • 11361 Answers
SOURCE: power comes on but screen stays black
The backlight inverter board may be bad, or worst case will be bad lamp. You should look to see if the cable comes off the inverter board first. You may learn maore here:
http://www.insidemylaptop.com/category/5-gateway-laptops/
Please post back what you find.
Posted on Nov 15, 2009
bhagyavichar
  • 414 Answers
SOURCE: laptop turns on but screen stays black
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
for any further assistance u may plz leave comment and or testimonials at any point of time, so that i/we can help or u think it to b helpful..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 23, 2009
How do I replace the f1 fuse in my gateway 7326
Will it boot? Fan spin? LED's blink? Sound? Try connecting to a external monitor, does it show desktop? The screen is all black, no cursor at top left? No "ghost Image" in the screen when viewed in a bright light? I would look at the inverter board, backlighting, ribbon cable in the rear of the monitor, the LCD screen, your laptop has some miles on it. Not sure about a fuse on a laptop motherboard, don't see that often. Take a look at this may help you troubleshoot: http://www.youtube.com/watch?v=2Yi6GNFcP3w
ALSO Gateway Support may help: https://support.gateway.com/s/Mobile/Gateway/7305GZ/4694nv.shtml
Feb 08, 2013 | Gateway Computers & Internet
Black screen and fan shuts off
power supply not work proper or cpu is too much heat after start
Jun 08, 2012 | Gateway M-6755 Notebook
My Gateway MT6705 seems to power on because the blue light will come on and I will here the cd rom spin for a second and sometimes the fan but the screen never lights up and it seems like the laptop is...
1. Your pc have a bad LCD and will have to serviced
2. If the blue light is the indication of proper "on" status then you have a malfunction
in the video/LCD
I am not sure of the repair cost but a qualified tech can determine this.
3. Check if you have inadvertently turn your brightness down or put the laptop in sleep
mode.
IF you have dropped the laptop you could have disconnected the video cable that go to
the LCD screen
Oct 07, 2010 | Gateway MT6705 Notebook
Gateway Laptop W340UA black screen
  1. take out the memory
  2. turn on again without memory (you should hear long beep sound) and turn it off again
  3. clean memory using eraser (better if you have spare memory to replace it)
  4. now try again
  5. if not working, checks whether the work properly? and clean the fan from dust. and try to switch it on again.
I look forward to hearing further.
Dec 14, 2009 | Gateway Computers & Internet
Gateway notebook problem
Black Screen of Death - BSoD Black Screen of Death or BSoD computer dictionary definition and information.
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Gateway 450ROG Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
