I have Yamaha HTR-5890 power up issue
I have Yamaha HTR-5890 and under a 75% load connected to my Yamaha NS-777's the receiver shut off..when I tried to power it back up..the relay would click and nothing. After removing the cover I noticed one of the 2 fuses was blown. The top one, its been a hardtime just finding the fuse alone..but could this resolve the problem or could it be alot more serious? Receiver was set to 6ohm for the NS's..I bought another receiver since then and im just not satisfied with it. Any input would be greatly appreciated!!
5 Suggested Answers
  • 14 Answers
SOURCE: Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
Posted on Sep 08, 2009
  • 3 Answers
SOURCE: I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Posted on Aug 10, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do I properly wire
According to each product's manual.
Bose.com for the 201's.
Register and download the HTR manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
SUB???
Posted on May 15, 2011
Testimonial: "Thanks for the intel ,i found what i needed "
dunnbiker
  • 8546 Answers
SOURCE: How do I factory reset
Page 63 of the manual.
Posted on Jun 07, 2011
I have 4 speakers connected 2 on A channel and 2 on B channel....Was listening to a dvd music concert at + 1.5 volume on my Yamaha HTR 5890 receiver,after 5 min my amp shut off and I was never...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Yamaha-HTR-5890-Receivers-review-manual/id/394ci071/t/1-2/
Page 25 discusses the minimum speaker impedance setting for expected lower-than-8-ohm loads. Running A AND B may present a load that is dangerously low. BTW: 6 is not a whole lot lower than 8.
Look at your speakers' impedance specs. Running them in parallel would present a much lower load than either pair alone.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You very well may have blown and amp or a speaker.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked
Mar 04, 2011 | Yamaha HTR-5890 Receiver
Feb 02, 2010 | Yamaha HTR-5890 Receiver
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Dec 29, 2009 | Yamaha HTR-5890 Receiver
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Yamaha HTR-5890 Receiver
The receiver is not turning on. Try all possible solutions ie;Power cord. What is cicurity protection and how do I check for that or correct?
Circuitry protection means the unit is overheating so a fuse blows and shuts down the power to save the electrical components.  You need to find the fuse and replace it.
Oct 25, 2009 | Yamaha HTR-5890 Receiver
Sep 08, 2009 | Yamaha HTR-5890 Receiver
120 people viewed this question
 Grubhead
Grubhead
