Question about Electric Lawn Mower
Qualcast Electric lawn raker/scarifier 1200 watt engine burnt out
Can anyone give me a local East Midlands company that repairs or supplies refurbished motors
    Sergeant:
  • 342 Answers
Hi Wudi the problem is motor rewinders are few and far between. You could try heritage in the west midlands if it's not to far.
Posted on Apr 15, 2014
Why does the front roller keep dropping, resulting in lawn scalpage?
Is the adjuster broken or wore out so it won't hold where it is suppose too be. Some times you just need to tighten the bolts that holds them on. You may have to replace the adjuster as well.
Jul 27, 2015 | Garden
How do i get the local news channel on bbc ?
What device? Aerial or satellite? If it's Freeview, you'd have to get your signal from another transmitter, which may not be possible from your location. It would probably mean moving or even changing your aerial. If it's a satellite receiver, you can select different regions or, on some devices, put in a different postcode based on the area you want to receive.
Aug 14, 2014 | Televison & Video
Qualcast electric xr35 reel mower and I need a new rubber drive belt for it
It's as easy as Google-ing "Qualcast spares", the choice of suppliers is amazing. Most give next day or 3-5 day delivery.
Aug 31, 2013 | Garden
I need the size of the poly v belt for a qualcast 4000 lawnmower.
Most time you don't have to get original parts like belts from the manufacturer. Suggest you go to a reputable lawn and tractor supply store where they can easily measure the belt and give you a comparable one for your machine. Hope this helps!
Mar 26, 2012 | Computers & Internet
Model JVM1442-001 What is wattage??
Wattage is a term used to express magnitude of power. A common use is to define the electrical power consumption of your home appliances (check the labels). For example, look at the back label of your kitchen toaster. It might read 120 volts, 60 Hz, and 1200 Watts. The 1200 Watts is the power drawn by your toaster when you turn it on. You can get that (Watts) information for any appliance or device that runs on electricity in your house. That's important because that is the unit of measure the electric company uses to charge you in your electricity bill. The electric company bills your electric consumption in kilowatt-hour (KWH). All they are doing is calculating the watts by the thousands (that's the meaning of "kilo") for every hour you have your appliance turned on. The amount 22 cents per kilowatt-hour is close to how much the electricity is costing today. Back to your toaster, 1200 watts is equal to 1.2kilowatts. If you are using your toaster every day for an hour your monthly consumption is 1.2KWH times 30 days equals to 36KWH. That means at 22 cents per kilowatt-hour your toaster is costing you (36KWH times 22cents/KWH) $7.92 on that month. That's the toaster alone, now you can repeat this exercise for every appliance or device using electricity in your home. Start by just doing an inventory of each, do a log with four columns: (1)Name of the appliance, (2)Location, (3)Watts, and (4)Watts/1000 (to get the number in KW). Make a fifth (5) column and call it Hours. Make a sixth (6) column and call it KWH. Then sit down to estimate (think) for how many hours per month each device is turned on. Now multiply each value of column 4 by its corresponding hour number in column 5. Write the results in column 6. Add the results of column 6 and voila! You just have a pretty good estimate of the total KWH consumed in your home in 30 days. Multiply that by $0.22 (or get the actual cost per KWH from your electric service company) and see how close you are to the actual billing. Hope there is no surprises.
There are the science and engineering definitions of the term watt you can research to come to the same conclusion hereto, I just laid a practical perspective.
Dec 18, 2010 | GE Microwave Ovens
Instruction manual required for Qualcast QX scarifier
www.qualcast.co.uk/rightmower/ then click on owner section and download manuak u need. Hope this helped.
Sep 29, 2009 | Garden
CAN LOCAL ENGINEERS REPAIR TURBOCHEF TORNADO OVEN?
I would go ahead and give that a try using the local guy. It may just be a burned wire and they coould fixit right there. Always support the local engineers that way if you have a emergency they will bend over backwarsds to help out.
Jan 15, 2009 | TurboChef TORNADO Electric Oven
Electric Lawn Mower Logo
129 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
