Question about Electrical Supplies
Need to find parts for Canadian tire no-name generator.
Need a carb.
I have a colemon 4600 generater only fires if put gas in the cab ureter then it starts but won't keep running any ideas
Likely that this unit sat for a while and developed a bunch of gunk/gum in the carb. Sometimes it can help if you do the following:
Find the idle mixture screw. This is the one on the side of the carb with a spring around it. Carefully not how many turns and Turn it clockwise until it stops. Make a note of this, then counterclockwise turn it until it comes out. Spray a generous amount of Carb cleaner into the hole. wait 10 minutes and repeat.. Put the screw all the way back in, then back it out exactly the number of turns you noted.
Try the engine, if it's still not right, you'll have to rebuild the carb.
Apr 03, 2017 | Electrical Supplies
Need a carburator for a powermate 6000
Hello Diana,
My name is Larry Boccioletti, I am a coleman repairman from Ontairo Canada. The Coleman you have I am presuming is a generator. Coleman do not supply engine parts for the generator.
If you can supply me the serial number I will try and locate what horsepower your unit is and the engine manufacturer. I will also
get you the part number and Canadian price for the carb.
That's the best I can do for now.
Thanks
larry_ boccioletti@yahoo.ca
May 18, 2015 | Coleman Powermate Powermate 5000W...
Who to may the guard on a miter saw move when it is pushed down.
The guard should move freely, if it is not it is either bent or mounted wrong. Find the make and model number and check with the manufacturer about getting an exploded view diagram with part numbers. Comparing the diagram to the machine should answer your question.
Jan 08, 2015 | Canadian Tire Corporation Canadian Tire
I Purchased a swivel stool, 068-0932-2 (29" stool) and it was missing the 4 leg parts (Part D). How do I obtain these parts?
I would return it where I purchased it. I find Canadian Tire has been very good when I have to return items.
Dec 28, 2014 | Computers & Internet
Variable speed control board for my router does not work. The board part has a number 1303
see if you can locate the manufacturer's website . even thru canadian tire .I could not find anything here
Oct 16, 2017 | Garden
I have a 2001 CRV. The replacement alternator has 4 prong plug. The one on the car has a green 3 prong plug?
Here's the problem:
http://honda-tech.com/showthread.php?t=2624894
Sounds like you have a Canadian SiR harness (all Candian 6th gen civics use a 3 wire alternator plug instead of the USDM 4 wire setup, IIRC its because the Canadian civics don't have an ELD) easiest thing to do in this situation is to reuse the original SiR alternator.
Don't know where you live or where you bought the vehicle but it's Canadian. Next time you need parts be sure and tell your supplier that it needs Canadian parts.
Oct 05, 2012 | Honda Alternator Crv 1999 99 2000 00 2001...
Points redeemed for Canadian Tire $250. Have not rec'd?
You need to contact Canadian Tire support. This site has nothing to do with them.
Sep 03, 2012 | perksplus.com
Canadian tire says tests fine. bought new battery,
open hood and check pcm wiring harness its located in the left back end of the engine compartment looking at it from the front of the vehicle. the wiring tends to become very loose
Feb 12, 2010 | 1994 Jeep Grand Cherokee
WHAT VOLTAGE ALTERNATOR DO i NEED
110 to 130 AMPS
you can buy them at autozone and they will make sure you get the right one... if you live in canada... canadian tire has them
Mar 20, 2009 | 2001 Ford Windstar
Electrical Supplies Logo
63 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
