Question about Briel Domus Due Espresso Machine & Coffee Maker
Cleaning oils from briel domus
Can I use a blind filter for backflushing on these machines? and does it have a pressure release mechanism somewhere?
    President:
  • 1,618 Answers
Yes, every pump driven machine has an over pressure discharge.
Posted on Jun 19, 2009
I need a printable manual
yes, they make it pretty hard to find but I eventually found it on the Breil website, this covers several machines including the Domus Due:
http://www.brielbg.com/pdf_instrukcii/004.pdf
Jan 15, 2012 | Briel Domus Due Espresso Machine & Coffee...
I have a Briel MultiPro espresso maker. When I try to make coffee, water/coffee starts running over the edge of the basket and it "spurts" coffee and grounds after a few seconds.
The group head gasket needs to be cleaned or replaced. First get a brush and clean put the head, then insert back wash filter(basket with no holes) in portafilter, make sure that it is seated properly(atleast 90° angle with machine), then run the head if nothing leaks around the portafilter the gasket is fine, if it leaks then replace the gasket. Make sure that you press the stop button before removing the back wash filter.
Jun 23, 2009 | Briel MultiPro Espresso Maker - Brushed...
Manual Briel ES161atb
Don't know about replacement parts but instruction manual can be downloaded from the website in PDF file.
Jun 13, 2009 | Briel Domus Due Espresso Machine & Coffee...
Briel Apollo no water when making espresso
Check that the water tank is seated properly. When you lower it in place just give it a little nudge down to make sure its slotted into the catch.
Nov 24, 2008 | Briel Domus Due Espresso Machine & Coffee...
Spares for Briel Coffee Machine
You can obtain any part at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Nov 12, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel Versatile Due Coffee Machine
You can get it at the Briel service/distribution center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Sep 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel domus duo espresso repair
There is a repair center in NJ at:
Electra-Craft
41 Woodbine St
ph 201-439-1700
If you don't want to send it all the way there you can contact a local restaurant in your area that serves espresso, ask who they use for repairing their espresso machine, and ask the repair company to contact Electra-Craft for parts and fix it for you.
Apr 09, 2008 | Briel Domus Due Espresso Machine & Coffee...
Espresso maker not workin properly
Your Brew Head screen and/or filter basket might be clogged with coffee oils. You can soak both pieces in a product that removes coffee oils from either www.urnex.com or Dezcal brand. Coffee shops will do this once a day. If you have the filter basket with the screw in the middle, you will need to remove the screw and soak everything as it can clog also.
If that does not work (it should tho) you can contact the Briel service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Leaks From Filter Gasket
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen and filter holder in a coffee oil remover by www.urnex.com or dezcal. Remove the screw if your filter basket has one. For home use it would be good to clean this every week or so. You can email me for more info: irene@smithagy.net. You also might just try purchasing a new filter basket (along with cleaning the Brew head screen and new basket).
Further technical info can be found at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Dec 20, 2007 | Briel Domus Due Espresso Machine & Coffee...
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
ph 201-439-1700
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Briel Domus Due Espresso Machine & Coffee Maker Logo
227 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Dennis Fitzsimmons
Level 1 Expert
Tom Chichester
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
