Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
I have a bosch dishwasher that wont drain
Its a classixx 6 months old still under warrenty but bosch says if they send someone out and its blocked i get charged for it but i can access the pipes and lost the manual grrr help!!
  • wendy9379 Jun 18, 2009
    I bought it from co-op and i have spoken to them and thats what they have told me does anyone know how to get to the pipe its stuck in the back and i cant get to it thanks
How do you operate ,adjust feet on Bosch Classix Dishwasher. What tool is right to get feet up or down?--- Are there four feet on machine?
Posted on Sep 09, 2012
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 181 Answers
Question! Did u buy this from Bosch? If you did not, then your contract is with the Store you bought it from and NOT Bosch and you should be contacting them and they should sort the problem.
A blockage, can sometimes be solved by putting one of those diswasher cleaning tabs in the machine a couple of times and see if that sorts the problem for you.
I suggest do that first it is the cheapest option and then if that does not work ring who you bought it from whether that be a retailer or Bosch themselves.
Posted on Jun 18, 2009
  • cashquest Jun 19, 2009
    If the machine is 6 months old, IT IS STILL UNDER WARRANTY!!!! Arrange for the Co-op engineer to come out, you would not expect a new machine to block unless you are putting plates in there full of food (which I assume you are not) All retailers are told to FOB customers off, Trust Me I used to work for Comet, stand your ground, just say it will not drain dont sya I think its blocked! If you dont want to do this then I would not suggest you D.I Y. the problem.
Dishwasher wont drain
Drain filter/catch basin is most likely blocked with food. You should be able to access it by the inside of the dishwasher...check you manual if you have one for components.
Mar 01, 2015 | Bosch Classixx WFL 2066 Front Load Washer
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Machine wont empty properly pump seems to work. machine sounds like its operating normally bosch classixx dishwasher
dont use soap with jet dry or rinse aid in it. use regular cascade soap and fill completely with jet dry rinse agent. your unit is over sudzing .if this is helpfulto you send me a 4thumbs up post
Feb 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Nov 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
942 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
