Kenmore 110 won't drain or spin - Washing Machines
  • 113 Answers
SOURCE: my kenmore 90 series model # 110,c28922790 will not spin
Your motor coupler is broken, its # 13 on the diagram, part # is 285753, you can live chat with me and Ill describe how to install it, hope this helps, dave www.washermd.com
Posted on Dec 17, 2008
appldoctom
  • 311 Answers
SOURCE: KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Posted on Jan 04, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 1122 Answers
SOURCE: Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
Posted on May 26, 2009
SOURCE: Kenmore Washing machine model 110-26422300 no spin
k, got this licked. 110 kenmore washer is a direct drive washer. the problem when it does everything fine but won't spin is in the transmission. took the motor trans assembly out. removed the cover for the transmission. removed the first big nylon gear on top and revealed 2 sets of swing arms. be careful to note how everything is assembled here. technically difficulty would be expert. the small nylon arm is worn. i drilled a small hole on the end at contact point and put a brass thumbtack to compensate for the wear on the swingarm. then filed the brass tack so that it would comply with the profile necessary once the gear was back in place. filled the trans back up with 20-50 motor oil. cleaned and sealed the case and reinstalled. I now have spin cycle. yay!!! ultimately the problem comes down to wear on the nylon swingarm. if you hear a faint click and no spin when in spin cycle this is most likely your problem. if you hear tons of noise you may be looking at a bad clutch. adios amigos!!
Posted on Dec 27, 2009
My washing machine does not spin and drain?
Why won my washer spin or drain Kenmore 110 Series Washing Machine
Since you gave no make or model info I can only give general "GENERIC" causes.
Feb 21, 2017 | Washing Machines
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
KENMORE WASHER MODEL 110 92588210 DRAINS WATER DOESN'T SPIN
You might have an issue with the spin gear in the gearcase.
May 31, 2012 | Kenmore Washing Machines
Kenmore series 70 washer will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
