Question about Candy EVOW6853D
E04 The code E04 is displayed and I can't open the door or select a different program
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
Sep 10, 2014 | Washing Machines
Getting a E04 error code
According to siemens website Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book. Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens WFXD5200UC Front Load Washer
My display on my Hamilton beach 2-way brewer reads E04
E04 is an input error. Wiggle all the buttons and make sure none are stuck down. The error codes actually aren't in the manual.
Mar 05, 2013 | Hamilton Beach Black 2-Way Brewer
E04 Error
E04 is a time out on the heating phase, to confirm this run a cold cycle, if the machine completes the cycle but sticks on any program above 40 degrees, best bet it's a faulty heating element.
Nov 27, 2011 | Bosch Washing Machines
Danby dpac120068 blue light flashing with error code E04 and the compressor keeps turning off randomly. What is causing this? What does E04 mean?
E04 refers to Overheating. There might be plenty of reasons. You might have seen, if you shut down the ac for few minutes and again start it, It would work for few minutes and the same E04 display is there.
This is tech's job. I am sorry, i am not discouraging you but it requires certain testing that actually what makes ac overheated.
This is dangerous. So, better to call a tech and get it checked!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | Danby DPAC120068 Air Conditioner
Error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Jul 27, 2008 | Washing Machines
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Candy EVOW6853D Logo
18 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
