Question about Home Security
Registry safe won't open with the backup battery
2 Suggested Answers
the recycler
  • 22 Answers
SOURCE: registry
Click on Start, then click on Run. When the run window opens, type 'regedit' without the quotes and click OK.
Posted on Feb 25, 2009
Speed up PC.-no virus/spyware,disk,
If you are determined to risk registry cleaning, you might try Wise Registry Cleaner, Glary's registry cleaner, or the registry cleaner in CCleaner or the commercial Advanced System Mechanic. You may use Revo Uninstaller to completely remove the programs you installed immediately before trouble emerged or resort to accessing the registry backup you created before cleaning. Many of the cleaners allow creation of such backups from within the software..
Sooner or later, registry cleaning seems to result in a "gotcha." You will be glad you had system restore points when that day happens. I try to leave registry junk alone, use portable apps to avoid installs affecting the registry, and make a restore point prior to every software installation.
How do you determine what is safe to clean? Well, Wise Registry Cleaner rather gives you a screen which suggests what is purportedly completely safe to remove by the screen colors indicating safe ones. If you have any doubts, don't remove the registry entry.
Not that the advice will keep you completely safe! Backup your critical data files to an external hard drive before engaging in too much registry tampering. As you chase performance, cleaning suites sound like a good option, right up to the point you crash, then you are chasing recovery options.
Use of Sandboxes and Virtual Drives avoid some garbage collection but that far more than you have requested to know about.
Adding ram sped up XP machines more than registry tweaks ever did.
Feb 13, 2015 | HP Desktop Computers - Hewlett-Packard...
Tip
How to restore the registry in server 2008
Registry is the heart and soul of any operating system. If you have done any edit in registry you should know how to backup windows registry. You can restore Windows 2000, Windows XP, Windows Server 2003, Windows Vista, and Windows Server 2008 by this method. Before restoring backup you should login with administrator and all open application should be close.
Follow these easy steps to backup registry:-
1. Click Start, and then click Run.
2. In the Open box, type "regedt32", and then click ok.
3. On the Registry menu, click Import.
4. In the open inbox, select .reg backup file and click ok.
after restore you can reboot your system.
on Jun 15, 2012 | Microsoft Computers & Internet
Windows won't start with safe mode (windows7 i meant)
Do you have the Restoration/Restore Disk?
If so pop it in the optical drive (CD/DVD drive), and when asked choose Repair.
(Non-Destructive Installation)
Post back in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
I'm getting the registry file failure screen it
If you unplug, remove battery, plug in, reboot to the system restore.
Dec 11, 2012 | Computers & Internet
My dvd-ram doesnt read original dvd,why?what can i do i have to do to makeit work?when i insert the original dvd it doesnt appear on pc.thank you
Hi lorena,
    Here is what I suggest you try.
  • Download and install CCleaner (free) from Piriform- http://www.piriform.com/ccleaner
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
If this does not resolve your problem, try the following
If VLC will not play a CD/DVD, try this,
    • Use the Device Manager and uninstall the burners drivers
    • Run the Registry cleaner in CCleaner again, this time in Windows Safe Mode. Remember to backup the Registry
    • Reboot, Windows should reinstall the DVD burner
If you take all these step and you still can not play a CD/DVD, chances are your CD/DVD componet needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
Dec 29, 2010 | LG GSA-H55N DVD-RAM Burner
My windows installer registery is somehow missing files
This error is caused by an Installation file that is called .msi or application is file that installs a program and it happen when that particular program is improperly installed. If you suspect such a software than you should remove it and to avoid such problems you should avoid other software running while installing a new software to be on the safe side.
Please take a backup of your Windows registry at first
To backup the registry go to Start>Run box or Search Programs and files> type Regedit. When the registry window opens click File>export and give the name to the file and select and remember the location and enter. This will take the back up of the registry.
Now obtain a good registry cleaning software. I recommend ReCure or registry Mechanic make sure the versions are the latest. One of the best Registry software is Uniblue Registry Booster. It takes registry backup automatically. These software should be able to fix your problem.
It is also recommended that you see the following link, This software can also make a difference to you
http://www.instant-registry-fixes.org/windows-repair-installer-configuration-information/
Good Luck!
Jul 22, 2010 | Microsoft Windows XP Professional With...
I weant to remove genuine microsoft software from
IF you mean the "Genuine Microsoft Software" notification that keeps popping up you can try this:
Following three simple steps now you can get rid of the pesky and sometimes buggy Windows Genuine Advantage (WGA) notifications:
1. Reboot Windows in safe mode (hold the f8 key while booting and you will get the option to boot in safe mode) and then:
2. Open Registry Editor (regedit.exe) and search for wgalogon folder and delete it. You should backup up the registry beforehand, in case somethiong goes wrong.
3. In your windows directory search for files wga* and delete them.
You are done!
Now reboot back normally and continue your work. Windows Genuine Advantage will not bother you anymore.
IMPORTANT: This involves editing the Windows Registry. Make a registry backup by selecting "Export" from the "File" drop down menu in "RegEdit". Selecting a name to save the file under. Make sure "My Computer" highlighted in software so the entire Registry is backed up.
Never make changes to the registry without making a backup copy of it first.
If your system misbehaves run "RegEdit" and select "Import" from the "File" menu. Navigate to where you stored the backup of the registry on your hard disk and restore the previous version before you made the changes.
Feb 05, 2010 | Microsoft Office 2003 Basic Edition...
Battery is dead - no green light.
Find out from Safe suppliers etc. where you can provide power to it and what kind of supply you need, and whether this changes the safe-opening procedure once it's powered up. Set it up and do it, open the safe...and probably change the battery.
Then try to remember who needed what backup service....
Jul 11, 2008 | Sentry Fireproof Safe
Home Security Logo
57 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
