Question about Hampton Bay 24002 Ceiling Fan
Ceiling fan ok, however light flickers when wall switch turned on. What is causing the flickering and how do we corrected it?
    Problem Solver:
  • 10 Answers
Check all the connections both in the fan and switch. Also the bulb. Replace bulb.
Posted on Apr 14, 2014
  • 653 Answers
SOURCE: Hampton Bay Ponte Vecchio ceiling fan light flickers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
Posted on Mar 01, 2009
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
SOURCE: Wall switch does not work
Light works but fan does not turn
Posted on Apr 26, 2009
techcrazy
  • 72 Answers
SOURCE: ceiling fan light the light keeps flickering then
this is due to vibration and the contacts get disconnected now and then from the surface.
i feel that you can sort out this problem by tightening the loosened connections of light.
Posted on Dec 29, 2009
SOURCE: Lights flicker on ceiling fan
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Posted on May 08, 2010
Lights in ceiling fan flicker when turned on
Make sure you have the correct wattage for the socket!
Mar 29, 2014 | Hunter Dryers
Flickering/buzzing CFLs when turning on W-32 and Casablanca fan. I had compact fluorescent lights in my Casablanca fan with an older W-11/12 swtich and the lights turned on cleanly. Then I upgraded to...
Is the difference that the new one is dimmable or you have installed a dimmer switch as well? If so thats the problem. CFL can't be dimmed and act weird on a transformer. Only option would be to open it and remove the dimmer pack inside the fan or swap to a normal wall switch.
May 04, 2011 | Casablanca Fan 3245T Ceiling
Lights flicker on and off. Fan works fine
mcdevito75 here, If the wireing in your home / apartment is old and especially if you have an A/C unit or refrigerator on the same circuit as the celing fan lights may flicker with these other appliances going on. --------------- You can also check the wall switch that turns the fan lights on.
Jul 21, 2010 | Hunter 20551 52" Vernazza Ceiling Fan
Minka aire concpet 1 ceiling fan issue
Ceiling fans have tiny "brains" that get fuddled when one tries to combine remote control and wall switches/pull chains. If you want to be able to use remote control, redo the installation omitting the other switches.
May 30, 2017 | Minka (F517ORB) Ceiling Fan
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Mar 01, 2009 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Ceiling fan light flecker
Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
Sep 02, 2017 | Casablanca Fan Stealth 3211T Ceiling
Wiring in Ceiling fan remote. Lights flicker
dip switches are not on the same signal?
Sep 07, 2008 | Hunter 27185 Remote Control
Hampton Bay 24002 Ceiling Fan Logo
111 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
