Question about Water Heaters
The heater starts leaking gas when the level in the canister gets low.
  • Water Heaters Master
  • 3,368 Answers
You are going to have to supply more information before somebody can help you. Make, model, etc.
Posted on May 03, 2014
Is this a dangerous gas leak?
Any gas leak is dangerous, call him back!!!!
Nov 19, 2014 | Water Heaters
Woke up to no hot water. Checked and found the pilot light out. Followed instructions to re-light. The red button I was supposed to hold down while lighting the pilot went down with no effort and would...
The red button sometime hangs up if the dial is not centered up. First check to see if the button is going all the way down. it should touch the gray box that has the temp dial on it.
If the button is going all the way down and you are still not getting gas to the pilot to light the main gas valve needs to be replaced. I dont know what your skill levels are so I am not going to tell you to replace it on your own.
If you do have the skills then replace the main gas valve, which means you have to drain the tank, go to Lowes or Home Depot get a valve that matchs up with you gas. Is it Natural or L P you MUST match the proper gas valve to the gas.
Make sure you test the gas connections with lots of soap an water for any leaks. Water leaks are no big deal Gas leaks will kill you and your family. I have seen with my own eye a house that gone after a gas leaked over night and they turn on a light and it was all over for 3 people BE VERY CAREFUL
Thanks Richard
Sep 06, 2011 | Rheem 40 Gallon FVR NATGAS Water Heater 6...
My heater control valve has a small leak it looks like water is dripping from it
Not enough information to fully answer question.
Control valve is usually associated with the gas line and gas control valve.
There should not be water dripping from control valve.
Open following link to help identify source of leak on tank-type water heater
http://waterheatertimer.org/Water-heater-is-leaking.html
If you are uncertain about parts on gas water heater, I suggest calling service technician.
There are several advantages. The technician can service the appliance and ensure there is no dangerous gas leaks or dangerous CO vent leaks.
And if your water heater is rusted and leaking, then service technician can prevent a possible flood.
Some gas is heavier than air and settles to floor, so always check for gas smell near floor level.
The combustion product from a water heater contains odorless CO which is poisonous, and must be vented outdoors so it will kill other things besides you.
The service technician can also see maintenance issues since gas water heaters require yearly maintenance, and some require more frequent attention.
Finally the service technician can give you a few tricks and tips for taking care of your water heater.
If you add a comment with the brand, type and model number of water heater, I can possibly locate a manual for that product which can help both you and me understand your water heater better.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Water Heaters
I have a 40 gallon rheem water heater for a mobil home that is leaking from the top.
If water heater is leaking, then open following 2 links to avoid tank rupture and troubleshoot leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Open following link if you want to install your own gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
40 gallon electric heater at Lowes costs 207, and is easy do-it-yourself using same basic information shown in link above for installing gas heater, except less work.
To have gas water heater installed, can run $2-300 for installation plus cost of heater.
40 gallon natural gas water heater at Lowes starts at $300+, and tanks with longer warranty cost more and last longer.
Trailers require specific type of gas water heater, so be sure to request correct model.
If you maintain the tank: keep chemicals out of same room as gas water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean gas burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Apr 08, 2011 | Water Heaters
Water leaking observed from the bottom of the tank. What's the problem? Should I replace the old 21V40-2 unit? if so, what kind of tank is ok to replace the present unit? What's the price and installation...
If you maintain the tank: keep chemicals out of same room as water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
Apr 07, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Rusted water heater must be replaced.
For money-saving water heater information:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have an Americdan Water Heater 50 gal. gas. 38000BTU the pilot light does not stay lit. what can i do?
Usual problems are:. Bad thermocouple, Bad vent, blowing pilot outl. Too small of pilot flame. Low gas pressure Leaking water heater, dripping on pilot. Bad gas valve. If your water heater is more than 8 years old and the gas valve is bad, I would replace the water heater. IF you decide to replace the pilot or the gas vavle, be sure to mount pilot exactly as is was designed. If you replace gas valve get an exact replacment or a "listed" replacement. If you'rd doing this and it's older, replace the temperature/relief vavle also. Water heaters can be very dangeroius if not properly repaired/maintained.
Jul 11, 2010 | Water Heaters
I have a Rheem glas fury model 22-40 gas water - leaking
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Oct 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
A.O. Smith Water Heater Problems
someone has messed with the differential setting - so the water heats to correct temp but cools too low before coming on. get book -easy fix
Oct 26, 2008 | Water Heaters
Water Heaters Logo
16 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
