Question about Refrigerators
Samsung RF4287HARS twin cool not blowing air at all in either section and no error codes come up on restart
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Check the fan or the damper motor
Posted on Apr 15, 2014
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Freezer and refrigerators sections are not
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 09, 2010
imufo2
  • 3773 Answers
SOURCE: I HAVE TWIN DOOR-SAMSUNG
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
Samsung RB1955SW refrigerator error code -2 / 44
I think that is your temperature setting that you set it it or could be the temperature in the case
Feb 22, 2018 | Refrigerators
Freezer freezes food, but why is ice cream melting?
Hi
It would be helpful for the model as some samsung models are single cooling and some twin cooling,please supply the model and i will be able to help.
Bryan
Dec 29, 2015 | Samsung French Door Refrigerator Right...
SAMSUNG REFRIGERATOR SHOWING CODE IE . POWER WENT OUT TODAY. HOW DO WE RESET IT?
Unplug the refrigerator for 5 minutes and plug it back. Now press "Energy Saver" and "Lighting" together and hold it for 3 seconds. It should clear the error message. Good luck!
Aug 24, 2014 | Samsung RF4287HARS French Door...
Samsung RF4287HARS 5E error
5e indicates a failed fresh food defrost sensor. It should be repaired by a qualified Samsung technician. It is an inexpensive repair, but further damage could be caused while accessing the sensor. Make sure the tech installs the new sensor on the evaporator outlet, and not back on the inlet.
May 12, 2014 | Samsung RF4287HARS French Door...
Samsung RF4287HARS not cooling and I cannot feel air blowing at all in either the fridge or freezer compartments Evaporator and fan at the bottom are running and unplugging and resetting does not bring up...
One possible senerio that could cause this is the coils are frozen up. If coils are frozen, no air can blow through the coils into either the freezer or refer section. This is caused bya failure of the defrost timer. (Don't know where it's located on yours but on an old one I owned, it was under the unit (accessible by removing a front cover) at the front. If the timer (or defrost coils) are not working, frost continues to build until te coil is frozen solid. This would oresent itself as a slow failure to cool, that is, each day (over 3-4 days) the refer section will get warmer.
Apr 14, 2014 | Refrigerators
A samsung fridge RF4287HARS has error codes 40E, 21E and 22E
Hello Jerry Fuller,
All your codes point to the same circuit pack.
Main Control Board ...DA41-00884a
PCB "CN76" low voltage condition... Low Voltage condition
(PCB = Printed circuit board)
CALL...
If you have any questions or comments relating to Samsung products,
55 STANDISH COURT MISSISSAUGA,
ONTARIO L5R 4B2 CANADA
Please contact the SAMSUNG customer care center.
SAMSUNG ELECTRONICS CANADA, INC.
TEL : 905-542-3535 FAX : 905-542-3835
1-800-SAMSUNG (7267864)
www.samsung.com/ca
owners manual
Samsung RF4287HARS User Manual
Service MANUAL (CODES on page 60)
Samsung RF4287HARS Service Manual
Feb 13, 2014 | Samsung RF4287HARS French Door...
The fan in my oven is blowing cold air when the oven is not in use
The fan will run on until it has cooled down the oven to a pre set temp.
Nov 30, 2013 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
My refri is working everything but is not getting cold ???
If your temperatures are higher than what you set it to be check your fans to make sure they are blowing cool air
Aug 11, 2013 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Error code OF OF
Try lighting and freezer for 3 seconds, or until you hear a beep. (The 2 left on my model) This worked both times I had the issue.
Jan 28, 2013 | Samsung RF4287HARS French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
