Question about Microsoft Office PowerPoint Home and Student 2007 for PC
Powerpoint 2007 Hyperlink problem
I am using Microsoft Office Home and Student 2007 and i am using Powerpoint and want to use a Hyperlink within the document to go to another slide ... i follow all of the steps but the "show and return" is not allowing me to access it ... as a result the hyperlink is not active
  • 39 Answers
Disable hyperlink warnings for 2007 Office programs loadTOCNode(2, 'moreinformation'); To disable the hyperlink warnings in 2007 Office Programs when an http:// address, notes:// or an ftp:// address is used, you must create a new registry subkey. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open dialog box, type regedit, and then click OK.
  3. In Registry Editor, locate one of the following registry subkeys:
    • HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Common
    • HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\12.0\Common
    NoteYou only have to modify one of these registry subkeys. You do not have to modify both of them.
    Note If the Security subkey already exists, skip to Step 6 after selecting the Security subkey.
  4. Click the registry subkey, point to New on the Edit menu, and then click Key.
  5. Type Security, and then press ENTER to name the key.
  6. On the Edit menu, point to New, and then click DWORD Value.
  7. Type DisableHyperlinkWarning, and then press ENTER to name the entry.
  8. In the right pane, right-click DisableHyperlinkWarning, and then click Modify.
  9. In the Edit DWORD Value dialog box, click Decimal, and then type 1 under Value data.
    Note A value of 0 enables the hyperlink warning message. A value of 1 disables the hyperlink warning message.
  10. Click OK.
  11. Exit Registry Editor.
Powerpoint 2007 Hyperlink problem - uparrow.gifBack to the top If you still receive a warning message loadTOCNode(2, 'moreinformation'); You may still receive a warning message from Microsoft Windows. If you continue to receive a warning message after you follow the steps in this article, use one of the following methods to resolve the issue. Method 1: Turn off the "Confirm open after download" option for the file type that you are trying to open loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer.
  2. On the Tools menu, click Folder Options.
  3. On the File Types tab, select the appropriate file name extension (for example, WMV) in the Registered File Types box, and then click Advanced.
  4. Click to clear the Confirm open after download check box, and then click OK.
  5. In the Folder Options dialog box, click Close.
Method 2: Modify the HKEY_CLASSES_ROOT\WMVFile\EditFlags registry subkey loadTOCNode(3, 'moreinformation'); Use this method if the warning message affects multiple computers.
To disable the warning message, follow these steps:
  1. Click Start, click Run, type regedit, and then click OK.
  2. Locate the following registry subkey: HKEY_CLASSES_ROOT\WMVFile\EditFlags
  3. Click EditFlags, and then click Rename on the Edit menu.
  4. Type OldEditFlags, and then press ENTER.
  5. On the Edit menu, point to New, and then click DWORD value.
  6. Type EditFlags, and then press ENTER.
  7. On the Edit menu, click Modify.
  8. In the Edit DWORD Value dialog box, click Hexadecimal under Base.
  9. Type 10000, and then click OK.
To re-enable the warning message, follow these steps:
  3. Click EditFlags, and then click Modify on the Edit menu.
  4. Type 0, and then click OK.
Posted on Jun 18, 2009
What's your problem?
Hi kasibual
MS OFFICE POWERPOINT HOME AND STUDENT 2007 ACADEMIC LICENSE
You do not say where you obtained your MS Office PowerPoint Home & Student 2007 Academic Version. If this program originally came from a Microsoft Authorized or other legitimate source with the original installation disc and Product ID and was, when new, an unused, unregistered, unactivated, genuine version but you have either mislaid or damaged the original disc, then you could beg, borrow or buy any MS Office Home & Student 2007 Academic Version disc with which to re-install the program, using your original Product ID when a code is requested during the installation process. You could borrow a disc from a friend or an educational institution. You could go to a local repair centre with a comprehensive software library. You could buy a replacement disc on eBay.
http://office.microsoft.com/en-gb/help/installation-and-activation-information-for-2007-microsoft-office-programs-HA010173340.aspx
If you obtained MS Office PowerPoint Home & Student 2007 Academic Version from a third party, you will have difficulty knowing whether it is genuine, unused, unactivated and unregistered.
If you were hoping to be able to download MS Office PowerPoint Home & Student 2007 Academic Version, then you should be aware that Product Full, genuine, licensed versions of Microsoft Products cannot usually be downloaded. Microsoft have withdrawn downloads and direct sales of MS Office 2007 applications, the only remaining support services being updates and security patches during Automatic Updates. If there is some obstacle to your installing , here are some constructive, useful, helpful, practical alternative options to consider instead. One option is to download MS Office 2010 Pro 60-Day Trial and install it, carefully following each step:
Go to: http://office.microsoft.com/en-us/try
If you do not want to buy or cannot afford a full, licensed copy of MS Office PowerPoint Home & Student 2007 Academic Version and/or prefer to pursue the downloading option, consider the latest version of genuine, similar free comprehensive Office Suite applications - OpenOffice and LibreOffice- downloadable free, from their original source, at:
www.openoffice.org
http://www.libreoffice.org/
You can use OpenOffice and LibreOffice simultaneously with MS Office 2010 Pro 60-DayTrial. If you delete MS Office 2010 Pro 60-Day Trial, well before the 60 day expiry date, and Remove all components of it from Add or Remove Programs (or its equivalent in your Operating System) and Restart before downloading and installing it again, it is usually possible to enter into further 60 Day trial periods. If you are determined to continue using it but there is some insurmountable obstacle to your installing MS Office 2007, then you might have to purchase a full, genuine, unused and licensed copy of the software from a reputable, reliable supplier, such as Amazon:
http://www.amazon.com/s/ref=nb_sb_ss_i_2_13?url=search-alias%3Daps&field-keywords=ms+publisher+2007&sprefix=MS+Publisher+#/ref=nb_sb_ss_i_0_18?url=search-alias%3Daps&field-keywords=ms+powerpoint+2007&sprefix=ms+powerpoint+2007&rh=i%3Aaps%2Ck%3Ams+powerpoint+2007
Online offers of Free Licences, Product keys or Downloads of MS Office products are probably almost universally either not genuine, illegal, unlicensed or pre-used licence versions, downloadable only from illicit download sites or sites that are masquerading non-existent MS Office products as camouflage for the marketing of other (often unrelated) software, products or services. Even if you do succeed in finding a Product ID or download site that seems to work for MS Office PowerPoint Home & Student 2007 Academic Version, you will still have to purchase a separate, genuine, unused Activation Code for the product before you can successfully install it, use it with confidence, register it, activate it and download and benefit from Updates and Security Patches for it from Microsoft.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 07, 2011 | Microsoft Office PowerPoint Home and...
Does Microsoft Office PowerPoint 2003 can be open in Microsoft Office PowerPoint 2007?
Yes Microsoft Office PowerPoint 2003 can be open in Microsoft Office PowerPoint 2007 But Microsoft Office PowerPoint 2007 cannot be open in Microsoft Office PowerPoint 2003
All the Best!
Jul 25, 2011 | Microsoft Office Home and Student 2007...
I need microsoft word 2007 version, it is easier to use
If your only after with word then i wold suggest you to get Office Home and Student cheaper and it has only 4 applications (excel, powerpoint,word and onenote) http://office.microsoft.com/en-us/home-and-student/
Jul 06, 2011 | Microsoft Office Professional 2007 Full...
I need to be able to put lesson plans into powerpoint form at home.
If you don't have PowerPoint at home you can use Google Docs to create a PowerPoint presentation, and then download it for use at school. You can also download and install OpenOffice, a free office program that is very compatible with Microsoft Office apps.
Nov 02, 2009 | Microsoft Office PowerPoint Home and...
Where can i get the key for all the microsoft? like excel and word? is it the same key for all?
if you buy a license for the office suite, it will only ask for the product key one time and it will unlock word, outlook, excel, powerpoint, and access. if you purchase the professional version, this will include publisher and any other office suite software.
Jul 11, 2009 | Microsoft Office Professional 2007 Full...
Microsoft office home and student 2007
You can download OpenOffice from www.openoffice.org. Its a free Office program that integrates great with Microsoft Office. It comes with a word processor, spreadsheets, presentations, graphics, databases and others.
Jun 22, 2008 | Computers & Internet
Microsoft Office PowerPoint Home and Student 2007 for PC Logo
2,663 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
