Question about Garden
Pump not running at 100%
My pressure is running at 60%, I'm thinking it has something to do with one of the o-rings inside the pump. Already remove the valve caps, but I'm having trouble trying to remove them as they don't want to move. I was thinking that if I disassembled the pump I could gently knock the valves out from the other direction. Problem now is I'm having trouble separating the two parts of the pump. Used a heat gun as I thought lock tight might have been used at the factory, but had no luck. Any suggestions would be great.
    Top Expert:
  • Garden Master
  • 48,235 Answers
First we need to know the make and type of pump , what it is fitted in and the purpose it is used for to get any sort a relevent answer
post the details along with your original statement as posts are not linked
Posted on May 15, 2017
  • 15 Answers
SOURCE: builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Posted on May 23, 2009
SOURCE: Karcher K 2400 HH Pressure Washer no pressure
Posted on Jun 05, 2009
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
Posted on Jul 25, 2009
  • 40 Answers
SOURCE: where is the unloader valve on my pressure washer
is not necessarily a cap, but could be a screw in plug, that should be close to the hose hook-up on the pump Inside there there should be a round ball and a spring that you can tighten or loosen to adjust the unloader and if it has been used ALOT, where the ball seats there could be grooves cut in there and you might need to get a valve kit to fix it
Posted on Sep 05, 2009
Dewalt d55153 runs continually trying to get up to pressure, but can't.
Just a guess but I think you have broken the rings inside. If you keep running it with broken rings you will trash the cylinder inside. I think you can buy a new pump for it if you are not mechanically minded.
Apr 22, 2014 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
How difficult is it to change the oil pump in a 1998 camaro(3800 V6)?
Should be inside the timing cover. You remove the timing cover to access the pump parts. Not really a pump assembly like pumps mounted inside oil pans.
I doubt the pump is faulty.
Have you checked the oil pressure with a mechanical gauge ?
Dec 18, 2012 | 1998 Chevrolet Camaro
How do you replace the fuel pump in a 1997 Ford thunderbird?
Electric Fuel Pump REMOVAL & INSTALLATION Non-Supercharged
  1. Disconnect the negative battery cable and properly relieve the fuel system pressure.
  2. Remove the fuel tank and place it on a bench.
  3. Remove any dirt that has accumulated around the fuel pump retaining flange so it will not enter the tank during pump removal and installation.
  4. Turn the fuel pump locking ring counterclockwise and remove the locking ring.
  5. Remove the fuel pump and bracket assembly. Remove and discard the seal ring. To install:
  6. Clean the fuel pump mounting flange, fuel tank mounting surface and seal ring groove.
  7. Apply a light coating of grease on a new seal ring to hold it in place during assembly and install in the seal ring groove.
  8. Install the fuel pump and bracket assembly carefully to ensure the filter is not damaged. Make sure the locating keys are in the keyways and the seal ring remains in the groove.
  9. Hold the pump assembly in place and install the locking ring finger-tight. Make sure all the locking tabs are under the tank lock ring tabs.
  10. Rotate the locking ring clockwise until the ring is against the stops.
  11. Install the fuel tank in the vehicle. Add a minimum of 10 gallons of fuel to the tank and check for leaks.
  12. Install a suitable fuel pressure gauge on the valve on the fuel rail.
  13. Turn the ignition switch from OFF to ON for 3 seconds. Repeat this procedure 5–10 times until the pressure gauge shows at least 35 psi. Check for fuel leaks.
  14. Remove the pressure gauge, start the engine and check for leaks. prev.gif next.gif
Aug 26, 2010 | 1997 Ford Thunderbird LX
My pump builds pressure to 60 psi but will not go any hire for the shut off what can be the problem
most jet pumps have a pressure switch to regulate cut in/ cut off pressure. Normally 40/60 psi. The pressure switch should be located at the rear of the pump where the wiring enters. First disconnect the power supply to the pump. Remove the cap where the wiring enters. On the inside of the cap there should be a diagram showing how to alter the cut in/ cut off pressure.
Jun 13, 2010 | Jet Plumbing
How do I replace the fuel pump in a 1991 audi a100
Oct 21, 2009 | 1992 Audi 100
Hesistation on pressure when trigger is pulled get n worse
Unloader valve is the most likely suspect here.
Remove and clean with penetrating oil then reinstall.
Also add some LIGHT oil into your supply hose via a small funnel. 3-in-1 household oil or power steering fluid lubricate the valve and pump quite well. Three or four treatments of a couple ounces each will usually make the pump happy again. If this unit has an OIL-FILLED pump on it you can expect good results. If it runs an OIL-LESS pump it is only rated for about 100 total hours of life!
Hope this helps.
Sep 26, 2009 | Honda Karcher G4000RH Pressure Washer
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a Fimco 2.1 gpm pump that worked fine last week. I ran it until it didn't spray anymore. This week the motor runs but it seems to have lost its prime,it won't pump.Any ideas? The filter is clean. No...
I don't think that these pumps run dry very well ... most likely you ruptured a diaphragm by running it dry. How long did it run dry? ... take it apart and see if the diaphragm or valves are damaged. You will need to replace them before the pump will work.
Jun 25, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
What is the correct fuel pressure on a 96 Dodge grand Caravan?
Don't have access to actual pressure required at this moment but I will tell you that 12-20 psi is definitely not enough. Your probably looking at a minimum of 50-60, and as much as 90-100 depending on what engine. A replacement for a 3.3.L at autozone is rated at 90-100 psi. I'd spend the money on new pump & filter at same time.
Mar 23, 2009 | 1996 Dodge Grand Caravan
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
