Question about Dryers
MY WHIRLPOOL DRYER IS NOT DRYING wed5300vw0 - Dryers
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
  • 1151 Answers
SOURCE: whirlpool dryer not drying all the way
As a general rule, your symtoms indicate that there is a lack of heat. Causes?= Obstructed vent. This causes overheating of the elements and they go out on a safety to prevent them from burning up.
One or more elements not working. Burnt out, bad safety (not working like it was designed to do), control to elements has malfunctioned.
Overload of clothes is possible but not probable.
On a long shot, check the plug, recept., and breaker. You may have lost a "Leg" of power to the unit and this is causing a "Low Voltage" condition.
Hope this is of some help.
Posted on May 09, 2009
roniecon
  • 6826 Answers
SOURCE: Whirlpool dryer WED5300VW0 runs and heats but
The timer has gone out,replace the timer with a new one.
Posted on Oct 10, 2009
Testimonial: "Thanks"
rogrrabbit
  • 986 Answers
SOURCE: whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Posted on Nov 11, 2009
    jsrock516
    • 5911 Answers
    SOURCE: Whirlpool WED5300VW0 dryer--gets hot, tumbles,
    If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
    http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
    The number one cause of dryer heat related problems is poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
    Posted on Jan 04, 2010
    Whirlpool dryer won't heat.
    Check for broken wire on heating element.
    May 15, 2016 | Whirlpool Dryers
    Whirlpool dryer,model WED5300VW0 is snagging my clothes. How can this be fixed?
    hello. You are going to need to inspect the bearing and front seal on the front of the drum, and also the bearing ring for front support. The rear of the drum is supported by two rollers underneath. First of all, here is a parts diagram for your dryer. On this first one, you can see the bearing ring for front support. Part number 36. It will need to be inspected for wear.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513301&diagram_id=28263302#d28263302
    The next thing that I would inspect is the front bearing and seal, which is part number 38 in this diagram. It will need to be inspected also.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513301&diagram_id=28129401#d28129401
    When these things are worn, it can cause the drum to drop slightly and snag your clothes. In order to take a look at these things, your going to have to know how to disassemble your dryer.
    You do this as follows;
    Pull your dryer out from the wall to avoid hitting the wall when you raise the cabinet top. Lift the lint screen access cover and remove the two screws inside. Do not remove the actual lint screen before you remove the screws. Removing the lint screen first could lead to accidentally dropping the screws down the lint screen shaft and into the blower wheel.
    If your older Whirlpool clothes dryer model has a kickplate, remove it first. You can either pop it off, or pry the kickplate off the interior spring catches. Depending on your model, you may have to use a putty knife to push in on the spring catch at the center of the top of the kickplate. With the kickplate removed, proceed to lift the cabinet top.
    Use a putty knife, or some other thin and flat object to wedge in under the cabinet top. Your goal is to push each of the two interior spring catches back out of the way, thereby releasing the cabinet top. The spring catches are located one on the left side under the cabinet top and one on the right side under the cabinet top.
    Loosen the two bottom screws securing the front panel to the unit. Do not remove them just yet. Locate the two screws at the inside top of the cabinet. They also help to secure the front panel to the dryer unit. Remove these two screws. Balance the front panel as best you can as you remove the two bottom screws that you have just loosened. Disconnect the wire leads connected to the door switch. Hold the dryer drum in place and remove the front panel of your dryer. Some models may have extra screws holding the front panel in place. If you are having difficulty removing the front panel, do a check for more screws.
    Reassembling the entire unit is basically the disassembly process in reverse. Reattach the front panel of the dryer in the same manner you took it off. Make sure you reattach the wire leads to the door switch, and replace all of the screws that were earlier removed.
    http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/3406129/2702?modelNumber=WED5300VW0#repairHelpVideoTabs You will want to watch this. It will tell you how to replace the seal on the door.
    http://www.repairclinic.com/PartDetail/Drum-Support-Bearing/279441/2683?modelNumber=WED5300VW0 this will show you how to replace the ring seal on the drum.
    These are so detailed, I think it's all that you'll need to complete job. These whirlpool dryers are not hard to work on once you know how to do it.
    I really hope this helps you. I hope that everything you need is covered here.
    Thanks,
    Mike
    Aug 06, 2011 | Dryers
    I have a Whirlpool model WED5300VW0, electric dryer. It's only 1 1/2 years old. The other night, I had a load of laundry going, and discovered it was still running after almost 3 hours. The laundry was...
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Yes, the timer is bad...
    That is not that hard to fix and you can easily buy the parts yourself online...
    Here is a tip that will help you with the online buying...
    How to Buy Appliance Parts Online
    heatman101
    Sep 08, 2010 | Whirlpool WED5300S Electric Dryer
    My new whirlpool dryer model WED5300VW0 Ser MO3398130 does not dry properly. It takes 2 hours for a load of towels to dry and even light loads do not dry properly. I just had my vent under the house...
    If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
    Here is the rest of this tip about Dryer Maintenance
    heatman101
    Aug 31, 2010 | Whirlpool LER5636P Electric Dryer
    This definitely appears to be an air flow problem. Take off the vent and see if it is blowing any air. If air, lots of it, comes out the dryer, the vent is clogged and needs cleared out. If no, or very little air blows out the dryer, the blower wheel could be broken, or there is a serious clog. Check the lint filter and look inside where it goes for anything that might be restricting the air.
    Jan 03, 2010 | Whirlpool Dryers
    Whirlpool dryer gold not drying clothes
  • Check the ignitor
  • Check gas jet
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    Dear Customer
    Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryers Logo
    41 people viewed this question
    Top Dryers Experts
