Question about Compaq Evo D510 PC Desktop
Can not ajust monitor icons are huge will not move from settings display settings stuck at 640 by 480 pixels
  • 4 Answers
Your display adapter is not installed, try to install it using your mortherboard installer....
Posted on Jun 18, 2009
Display issue
Good day!
go to display settings then click on monitor tab change graphic monitor to Generic PnP monitor or the installed VGA driver on your computer.
Mar 28, 2014 | ASUS X55C-XH31 15.6" Laptop
Red pixels
Try connecting an external monitor to the computer and check if the external monitor displays the same thing. If the external monitor is fine then you would need to fix the LCD of your laptop. or have it replaced.
If the external monitor displays the same thing, then you would need to update the video driver in your computer. You can use RadarSync to automatically update the drivers.
David
May 30, 2013 | Computers & Internet
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
Feb 22, 2013 | Acer Computers & Internet
I have a new Acer 23" LCD monitor - the desktop icons, my email, my word documents - everything is HUGE - I cannot read anything without going back and forth, up and down and it is impossible to type...
You need to change the monitor resolution setting in your operating system. If you are using Windows then go to Control Panel and look for Display Settings (or something similar depending on the version of Windows). Adjust the Resolution setting (probably using a slidebar on screen) to match the optimum setting of your monitor. If you don't have the monitor instructions try the highest setting first and move down one step at a time until you get a correct resolution on the display.
Jan 04, 2011 | Acer Computers & Internet
HP w1907 monitor has fuzzy text
Procedures of acquiring high definition pixel quality
1.power on the computer wait until the desktop of icons display after booting has been completed
2. using the arrow of the mouse or pointer to an area on the desktop without icons, right click to display a prompt list
3. locate the appearance and setting prompt on the list.
4. a click to provide the options to increase the picture quality termed pixels
5. LCD monitors could produce several thousand pixels, select a choice nearly approapiate for reasons explained
a. the highest selection of picture quality provided on the list for a monitor powered by a separate computer with extremely dense graphics like known for modern gaming could cause monitor to blank out as precaution.
b. when selecting a picture quality from the list provided on the appearance settings area after a right click on the desktop, be sure about the compartibility of the monitor and computer unit, explained
c. most modern retail provide system units with higest definition pixel capabilites for several funcitons as gaming graphic and design, connect such a unit to an old monitor would display low quality definition pictures. However, that could be fixed by adjusting the appearance setting only with caution not to select the most highest available from the list of pixels.
Dec 06, 2010 | HP w1907 LCD Monitor
Why is image on screen is to wide
A wide screen display requires setting the appearance
procedures
1. right click on a space on the desktop without icons
2. select from a list prompt the settings with click should provide link with which to select the appearance setting
3. choose from the display icon prompt after clicking a pixel quality
4. a larger figure chosen from the list should decompress the screen pixels creating clear pictures though adjusted screen to fit the area
Dec 06, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Screen icons and picture too big
What is the OS??
Right click on the desktop and click on "Properties", "seettings" and set screen resolution to at least 1024 X 768 for LCD monitor or 800 X 600 for CRT monitors.
If they are set to those then there may be a prob with video driver.
Need more in depth explaination.
Dec 21, 2009 | Dell OptiPlex 170L PC Desktop
My desktop icons change to huge size automatically
please check the display settings for screen resolution and set it to the optimal value as per your monitor....
Mar 07, 2009 | Computers & Internet
Dead pixel
Please read the WHOLE of this guide before starting. Software Method
  1. Try running pixel fixing software. Stuck pixels can often be re-energized by rapidly turning them on and off. If this fails, complete the following steps.
Pressure Method
  1. Turn off your computer's monitor.
  2. Get yourself a damp washcloth, so that you don't scratch your screen.
  3. Take a household pen, pencil, screwdriver, or some other sort of instrument with a focused, but relatively dull, point. A very good tool would be a PDA stylus.
  4. Fold the washcloth to make sure you don't accidentally puncture it and scratch the screen.
  5. Apply pressure through the folded washcloth with the instrument to exactly where the stuck pixel is. Try not to put pressure anywhere else, as this may make more stuck pixels.
  6. While applying pressure, turn on your computer and screen.
  7. Remove pressure and the stuck pixel should be gone. This works as the liquid in the liquid crystal has not spread into each little pixel. This liquid is used with the backlight on your monitor, allowing different amounts of light through, which creates the different colors.
Tapping Method
  1. Turn on the computer and LCD screen.
  2. Display a black image, which will show the stuck pixel very clearly against the background. (It is very important that you are showing a black image and not just a blank signal, as you need the backlighting of the LCD to be illuminating the back of the panel).
  3. Find a pen with a rounded end. A Sharpie marker with the cap on should be fine for this.
  4. Use the rounded end of the pen to gently tap where the stuck pixel is - not too hard to start with, just enough to see a quick white glow under the point of contact. If you didn't see a white glow, then you didn't tap hard enough, so use just slightly more pressure this time.
  5. Start tapping gently. Increase the pressure on the taps gradually for 5-10 taps until the pixel rights itself.
  6. Display a white image (an empty text document is good for this) to verify that you haven't accidentally caused more damage than you fixed.
Tips
  • If the pressure and tapping don't work directly on the stuck pixel, start moving outward around the stuck pixel. If you see the pixel flicker while doing this then you know where you can focus the pressure and tapping techniques rather than directly on the pixel.
  • Many people report success with this technique but these instructions won't work in every case. It may take a few attempts to make sure you are pressing exactly on the stuck pixel.
  • These instructions will fix "stuck" pixels, not "dead" ones. Dead pixels appear black while stuck pixels can be one constant color like red, blue or green.
  • An alternative, but similar technique involves gently massaging the stuck pixel with a warm damp (not wet) soft cloth.
  • Alternative technique to tapping: Using a rounded pencil eraser, push with moderate pressure into screen at stuck pixel.
  • If these instructions don't work, you can hopefully get the monitor replaced through your manufacturer. If your monitor falls under the specifications of replacement, get in contact with the manufacturer to set up replacement plans.
Warnings
  • Do not attempt to open the monitor as it will void the warranty and the manufacturer will not replace it.
  • Make sure you don't get any electrical equipment wet or it may break.
  • Some people claim that touching the screen can cause more pixels to become stuck, although this has not been proven.
  • Be prepared to suffer a complete loss; you may crack the glass when tapping or putting pressure on an LCD assembly.
**Rytech assumes no responsibility if you cause futher damage to your product whilst following this guide. If in doubt, contact authorised service personell**
Jun 20, 2008 | HP Compaq WF1907 Monitor
Compaq Evo D510 PC Desktop Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
