Question about Seiki 46" 1080p LCD TV - SC461TS
How to hook up Closed Caption
Looked in the menu and closed caption isn't highlighted. How do you turn it on?
    Master:
  • Seiki Master
  • 688 Answers
If you are using cable box or satelite box, you will need to turn on closed caption on that unit first.
Posted on May 09, 2014
How do I get closed captioning on my samsung 6300 TV
A Google search suggested this:
To turn on and set the Closed Caption function options, follow these steps:
  • Turn on your TV and STB.
  • Press the Menu button on your remote control. ...
  • Highlight Setup, and then press the OK button on your remote control. ...
  • Highlight Preferences, and then press the OK button. ...
  • Highlight Caption,and then press the OK button.
Jan 14, 2018 | Samsung Televison & Video
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to remove subtitles from sony bravia tv screen
You can download the user manual here.
http://www.retrevo.com/support/Toshiba-57H84-TVs-manual/id/311ag813/t/2/
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and sound effects of TV programs and videos that are closed captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the current program, such as weather or stock data (when provided by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2.Press MENU, and then press x or • to display CUSTOM menu.
3. Press y or z to highlight CC, and then press ENTER.
4. Press y or z to highlight CAPTION or TEXT, and then press Enter.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Apr 09, 2010 | Toshiba 57H84 57" Rear Projection...
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
The closed captioning won't turn off
get the remote, either press the closed caption button until it says off, or if there is no cc button, then go into the menu and find the closed caption and highlight off.
Sep 09, 2009 | Televison & Video
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
Black rectangle appears on 36" CRT. Needs reset?
Sounds like you are in close caption mode.
press the menu button and use the left and right arrow keys to highlight the 'closed caption menu"
press up or down arrows to select
navigate to closed caption off and highlight
the box should disappear
Download the user manual here:
http://www.devicemanuals.com/downloadguide.php
closed caption features start at page 30
Mar 12, 2009 | Toshiba 36AF41 36" TV
Seiki 46" 1080p LCD TV - SC461TS Logo
263 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
