Question about LG 60PK540 Plasma TV
60PK540 is plug into surge protector and has power just no screen display an no sound
  • larry lease Jun 09, 2014
    Hi jeromy young, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Do you have Stand by light(red LED) or power on light(green or blue LED) or any relay clicks?
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: surge protector
You can get the manual here. As for the surge pro. I would juct get one that is 15amp.
http://www.lge.com/support/manual.jsp
Good Luck and Please Rate FixYa!
Posted on Dec 29, 2008
  • 8457 Answers
SOURCE: There were power flickers due to DTE working on
Power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 16, 2010
Testimonial: "Thanks will look for one and try it out!"
freetek
  • 5568 Answers
SOURCE: No indicator light or power
Please look at these two links; I suspect your problem is related:
http://www.fixya.com/support/t4592070-tv_no_power_will_not_switch
http://www.fixya.com/support/t4596948-tv_stopped_working_bit_fizzing
This model seems to be having a ton of power supply problems.
Posted on Apr 21, 2010
gopakumarg43
  • 74377 Answers
SOURCE: have power to my tv but screen will come on
Unplug the TV from AC mains wall socket. Plug it back after 5 minutes or so. this must make the TV to a hard reset. Try this.
Posted on Jun 06, 2012
My hdmi ports aren't working when tried blank screen comes on I can plug the cable connection in and have cable
If you don't have it plugged into a surge protector box it may have fried your connections. If you do have a surge protector, try reseting or push power button on surge protector unit.
Aug 15, 2017 | Televison & Video
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Display on control panel no longer displays.
Surge associated with power outage can make disasters in refrigerators. You need a power protector for refrigerators.
Now, what already is damaged, should be repaired by an authorized techician.
For protector, you can do a search; typical return is this one
Electronic Surge Protector for Refrigerators up to 27 Cuft and Freezers
May 13, 2015 | Samsung RS277AC (27 cu. ft.) Side by Side...
My pos is all plugged in but the screen isnt coming on,i'm just getting the green power light.
Did you have a power surge lately? Is it attached to a surge protector? It sounds like a board got fried; maybe the screen, though.
May 03, 2015 | Samsung Touch Screen Sam4s Sps-2000 Cash...
Had power surge. Tv was on surge protector. Now no power will come on and just makes a buzzing sound.
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
Oct 25, 2012 | Televison & Video
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Had a power outage now the TV displays only a black screen, and doesn't respond to any remote functions except for power.
sounds like you may have also had a power spike and possibly fried the tv. have you tried unplugging the tv for about 30 mins and plugging it back in? some tv's have built in surge protectors that need to be re-set
May 14, 2011 | Toshiba 32CV510U LCD TV
Sony Grand WEGA KF42WE610 42" turns on and off
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Jun 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
LG 60PK540 Plasma TV Logo
Computer Repairing
Computer Repairing
