Question about Wahl 9878-114 Beard Trimmer
Where do I find a replacement battery for my model 9878 trimmer
How do I replace the battery in the nose and ear trimmer? Is this even a possibility? Mine is not a spotlight model.
You can, but getting into them is often the problem. They usually have some hidden screws and then locking tags that have to be pressed in just the right place with a plastic tool called a 'bludger'.. Best idea is to find a local service centre and take them in for battery replacement.
I had the battery in a Braun trimmer replaced this way.
Jul 11, 2016 | Wahl Deluxe Spotlight Ear Nose and Brow...
We like to get this model
You can get this battery and Batteries Plus or Home Depot.
Feb 16, 2016 | Garden
How do i replace my philips beard trimmer battery?
It depends on what model you have. For Example, this is how you replace the battery on a Philips QG3020 beard trimmer:
Philips QG3020 Disassembly Change Battery
You can write here your trimmer model, in order to get instructions for that.
Jan 29, 2015 | Philips Health & Beauty
Back put together trimmer
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer, which includes how to reassemble it: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Dec 09, 2013 | Remington MB-300 Beard Trimmer
I have a Black & Decker 12v, 12" cordless trimmer (CST2000). The charger is missing. Can I buy a replacement? Is there a part number?
Do a random Google search for your model and maybe even serial number and you will find what you are looking for.
Aug 30, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
What is the replacement battery for this trimmer?
The battery for my trimmer is a NiCad Sub C 1.2V 1500 Mah.
Do a Google search for it.
Get one without the solder tabs for the 9876.
I got mine here and snipped the tabs off.
I hope that this helps.
I do seem to have the trimmer in the picture.
Later!
The Shadow
Oct 20, 2009 | Wahl 9876-500 Beard Trimmer
Will not recharge
The batteries have a short life-span. Usually replacing the battery works. This is why this model frequently gets poor reviews and why I replaced mine with a corded model.
Aug 25, 2009 | Black & Decker Black and Decker & Grass...
After a few seconds the line stops spinning fast enough to cut through any weeds even on a full battery
This model has gotten some bad reviews because of the short battery lifetime. Mine started doing this after ~8 mo of use, so I replaced it with a corded model. Depending on how old it is, you can try (1) taking it back to where you purchased it, (2) calling a black and decker service center to replace the battery on their $, or (3) buying a replacement battery yourself. Sorry, but your battery is bad.
Aug 25, 2009 | Black & Decker String Trimmer Cordless 12"...
I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
Dec 27, 2008 | Ryobi 15" Electric Factory Reconditioned...
Broken hinge on Europa oven
try Ausralian Bakery and Pizza, Equipment Importers
122 Whitehorse Road, Blackburn, Victoria, Australia. 3130
Telephone: +61 3 9878 6900
Facsimile: +61 3 9878 6966
They import Europa equipment
Dec 04, 2008 | Creda Europa E010E Electric Single Oven
Wahl 9878-114 Beard Trimmer Logo
96 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
