Question about Gaggia Espresso Machine Academia Model 1003380, Silver, 1 ea
Add coffee indicator is on even though hopper is full.
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
Grinder spins. Hopper is full of beans. Why is no ground coffee dispensed?
You will probably find that the grinder is bunged up with grounds. This can happen if there is a bit too much steam inside the housings. The grounds bind together and will not drop with gravity. Pull the grinder apart, clean it out then run it with the top housing off and see if you can observe any leaks/steam. There will be some steam, you are looking for excessive steam.
Sep 13, 2015 | Miele CM 5200 Espresso Machine Black
My Jura Ena gives a 'fill beans' message even though the hopper is full and it won't grind the beans even though it seems to be operating. Help.
Mine just started doing the same thing. I've always only used plain espresso beans. Only thing is I may have overfilled the hopper and packed the beans down a bit. How can I make it start grinding again?
Sep 08, 2010 | Jura Capresso Jura Ena 3 Espresso Machine ...
My Jura Ena 5 gives a 'fill beans' message even though the hopper is full and it won't grind the beans even though it seems to be operating. Help.
Same thing happening to me right now. I think this has something to do with having used flavored beans (which I was warned not to do). Supposedly they gum up the machine.
Nov 27, 2009 | Jura Capresso Impressa S9 Coffee...
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Saeco Vienna is full of beans but the bean light stays on
the sensor may be stuck that tells the majer there are beens in it ..look in hopper feel around!
Nov 28, 2008 | Saeco Vienna De Luxe Espresso Machine
Toner
Di200 [Subject] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good. [Description] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
Gaggia Espresso Machine Academia Model 1003380, Silver, 1 ea Logo
328 people viewed this question
Top Gaggia Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Gaggia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
