Question about Video Game Consoles & Games
Need to see a NHRA top Fuel Schedule - Video Game Consoles & Games
Using web browser for NHRA all access get message Error loading player. no playable sources found.
Some streaming services have proprietary media players. I suggest contacting the NHRA at nhra@nhra.com and ask for technical streaming service support.
Mar 19, 2016 | Samsung Televison & Video
Im trying to run nhra drag racing2 on windows vista but I get a black screen when trying to play game although i can hear game music in background. the task manager screen says that the game is not...
Since the game was released in 2002 it may have a few problems running on today's systems. I would first try running it in compatibility mode. Right click on the icon you use to launch the game and go to properties. From there click on the compatibility tab. Select the check box that says "Run this program in compatibility mode for" and then from the drop-down box select Windows XP (Service Pack 3). Then click Apply and OK. Then try launching the game again and see if it runs any better. If not, try it again but in compatibility mode for XP (Service Pack 2). Good luck!
Jun 29, 2011 | Racing Nhra Drag Racing 2 for Windows
Dual distributor spark plug wiring diagram for model building.
You are correct in your idea about how the plug wires are attached. If you want to duplicate control wiring you would need to obtain the wiring diagram of the brand of ignition system you want to duplicate. (MSD etc. These systems also require a small battery in order for them to operate. Wiring to distributor was far less complex when vertex type magneto distributors sere used as all that was required was a ground wire to shut them down (exactly like your lawnmower works), As far as plumbing, all systems need to meet safety standards set forth by the NHRA but aside from meeting those standards, each engine builder decides where to locate such items as primary and secondary fuel injectors etc. If you go to the NHRA website, you may be able to find a decent photo of someones engine...that may be helpful. Also check the rule book for such items as kill switch location, brake, chute release etc.
Sep 12, 2009 | 1998 Pontiac Trans
A/C compressor won't engage.
I may be brain damaged, but not retarded...don't have a chart on that or I would give you relay location...not meteorologist, ex-nhra top fuel.
Aug 02, 2009 | Mazda B4000 Cars & Trucks
Video Game Consoles & Games Logo
54 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
