Question about Singer 7422
Singer SM MN 93234--pressure foot lifter won't stay lifted, falls down. What to do?
Pressure foot lifter does not stay up. Can't hold it up and sew.
Sorry can't help you there may be you need it check by a sewing machine mechanic may be a screw is lose and need to be tight.
Posted on Apr 14, 2014
  • Deborah Wright
    Deborah Wright Apr 16, 2014
    The pressure foot leaver probably has a loose screw of lever. You really should have a professional Sew-Vac person look at it. Check your local phone directory for one near you.
Janome 5124 pressure foot to keeps falling off.
Sounds like the presser foot holder is bad, get a new one.
May 25, 2017 | Janome Sewing Machines
The pressure foot will not lower/ seems like the pressure foot lifter is stripped or missing something...when I raise it, it falls back down but the pressure foot remains in the lifted position
Most likely something has become disconnected or misaligned. Perhaps it is time for a routine service call to your local sewing machine shop.
Jan 24, 2016 | Sewing Machines
How to fix a pressure foot lifter on a singer tradition
You can get a replacement Lifter from Sewing Parts Online here:
http://www.sewingpartsonline.com/presser-bar-lifter-singer-v880153000.aspx
Most likely, the screw end on the machine has broken off.
Jan 18, 2016 | Singer 2250 Tradition
Needle stays down, will not come up.
sounds like the machine froze up, machine needs to be serviced
Sep 25, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
Singer 9015
Sounds like the linkage between the lifter and foot is caput. If you open the case, you void the warranty.
May 22, 2014 | Singer Sewing Machines
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
The presser foot lifter on my machine is not engaging this allows the needle assembly to spin - is there a way to fix this?
Your question is not clear. The pressure foot lifter only lifts the pressure foot. It doesn't make the needle spin.
Apr 23, 2011 | Singer 5062 Mechanical Sewing Machine
GOOD DAY, THE ELNA 9000 WHICH I HAVE JUST BOUGHT 2ND HAND HAS A PROBLEM WITH THE PRESSSURE FOOT HANDLE. IT DOES NOT STAY IN PLACE, BUT KEEPS ON FALLING DOWN, AS IF A SPRING IS WORN OUT AND THE COTTON MAKES...
No pressure being applied to the pressure foot and therefore the fabric between it and the feed dogs means no feeding of the fabric.
The pressure foot has a spring up inside the head of the machine and this is probably broken causing this fault.
I would suggest that you take the machine to your local SM service technician..
Jan 28, 2011 | Elna 1010
Hello I have a singer model 4552 I cant make the pressure foot stay up...the lever doesnt raise the foot high enough what doi do?
I have a used unit with the same problem. If you remove the plastic housing piece on the far left you can see how the foot lifter works. Raising the lever raises a collar around the main shaft. There is a screw in that collar which connects the collar with the shaft. If that screw is loose the collar will not raise the shaft. Caution: Tighten the screw very carefully, only enough so that the shaft lifts. I just overtightened and the collar has a crack now.
Sep 30, 2009 | Singer Sewing Machines
On my singer 9005 the pressure foot lifter does not stay in the up position - does not hold the pressure foot up.
These plastic presser bar lifters do wear out a lot ,very common,,,,,,,,You can lift it up and file as close to the machine side on top just a couple of stroke son the file will usually give it a surface to hang on and it will stay up ,much easier than changing the plastic lever
Aug 09, 2008 | Singer 7444 Mechanical Sewing Machine
Singer 7422 Logo
76 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
