Question about Dometic Rooftop RV Air Conditioner
Dometic roof air compressor comes on but fan will not replaced both capacitors and thermostat
Control box is not clicking fan upstairs moves freely
    Sergeant:
    Champion:
  • 282 Answers
Sounde as if there is an open winding in the fan motor. There are two sets of windings in a fan motor. The start winding and the run winding.
Here is how you can tell if it is the start winding. Put the unit on and then take a stick and try turning the fan swiftly. If it does start and it could be in either direction, since you have already replaced the capacitors then if the start winding is open then you will need to replace the fan motor. Same goes if the run winding is open.
Posted on May 11, 2014
  • gary jennings
    gary jennings May 11, 2014
    thank you very much, thats the closes anwser yet. I no its been awhile will try tomrrow morning. the unit coming down and will be replaced with a 15000 btu you see had to way options $135 for new digital stat and new shroud $180 and a new fan motor whatever that cost . ill keep the unit and replace each item over time and then add the unit to this camper as an extra a/c , it gets hot in texas but thanknyou for the information. 2009 outback 32 fifth wheel two slides
motor1258
  • 6674 Answers
SOURCE: dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Posted on Aug 14, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Have a 2009 34' Cougar 5th wheel with a roof
Sounds like a bad contactor. The contactor will be near the compressor on the roof.
Posted on Mar 12, 2011
  • 230 Answers
SOURCE: will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Posted on Jun 17, 2008
  • 230 Answers
SOURCE: dometic roof air
Sounds like the unit either has been miswired from the beginning or there is a stuck contactor relay.
The more rare scenario is that the control wire between the t-stat and the contactor is shorting to a power source causing the relay to energize. Good Luck!
Posted on Jun 23, 2008
jmeredith
  • 417 Answers
SOURCE: compressor tries to start but want
hi,
you have to run a contractor grade extension cord(10-12 gauge) from your rv to run those or theyll do that, the lower the gauge the better, best bet is to plug the rv directly into the outlet, if you cant, get the shortest and thickest extension cord you can.
Posted on Aug 21, 2008
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
Dometic Duo Therm, 15000 BTU: Thermostat works, fan runs, but no cool air. Any ideas?
Check the compressor and the condenser fan to see if they are running;they will have to be checked from the roof. If one is running and not the other then check the capacitor for the one that's not. If both are off then check the contactor that controls them. You will also want to make sure they are getting power. If they have power and the capacitors are good, check the motor windings for the fan and compressor. Hope this helps. Let me know what you find.
Aug 04, 2010 | Dometic Rooftop RV Air Conditioner
AC won't start. Fan runs
Depending on make & model, usually if you hear a "click" at control box at ceiling when switched to cool, that's a good indication of a faulty relay, capacitor , or maybe even compressor. Not something to play with if not experienced, especially capacitor. Have someone who knows electrical troubleshooting check voltages at compressor and you should be able to back-track from there and isolate problem. If no clicking at ceiling when asking for cool, check thermostat, then control box connections etc at ceiling. Need more info such as make and model number as well as thermostat type if more questions please.
Apr 27, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm kicking on the compressor, getting cold, but no fan!
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
Compressor doesnt come on in a dometic duotherm rooftop ac unit.Fan runs but no compressor
If this is a wall thermostat controlled unit, then check to make sure that you have power coming from the yellow wire on the thermostat when it is placed in the Cool/Auto High mode. If you do not have power at the yellow wire, then you have a bad thermostat. If you do have power, then remove the control unit from the inside of the AC and see if you have power at the Y terminal there. If so, when you turn the thermostat to cool, can you hear a relay clicking in the box? If not, then you have a bad control box. If the relay is clicking, you need to check the power at the compressor relay on the board. It has a black wire to one side and a purple (or blue) wire on the outgoing side. Check to see if you have 120V on the blue wire when the tstat is set to High/Cool. If not, then you need to bypass the freeze switch to make sure that is not the problem. If you do, then you need to go upstairs and check the start capacitor for OK. It is located in the side compartment of the upper unit, it has a small black relay on the top called a PTCR. These often burn out and will cause the compressor not to work. If that is fine, then you go to the top of the compressor to the thermal overload switch. See if you have power at both sides, if so, then you have a bad compressor. If not, then the overload switch is open and not allowing power to the compressor.
Jun 25, 2009 | Dometic Rooftop RV Air Conditioner
Compressor tries to start but want
hi,
Aug 21, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
338 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
