Question about Saws
Bosch 15-82 blades - Saws
  • Charles Karcher Jun 21, 2014
    Hi Bob Evans, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    I can only imagine fifteen pack and can not connect to the 82. What is the saw model? And exact blade fit?
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
Bosch plunge saw , why does the blade slip when cutting
Richard are you using correct Bosch blades ( some blades are not correct thickness), is spindle bolt tight, spindle washer is not worn or cracked,oily, dirty, etc.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 19, 2016 | Bosch Saws
Change blades bosch jigsaw
The one shown in the picture uses a very long and thin, flat blade screwdriver. There is a set screw that puts tension on the blade when the screw is tightened. Bosch sells the correct screwdriver or you can buy a long one and grind the sides down a bit. That's what I did.
May 17, 2012 | Bosch GST80PBE JIG SAW FOR 220 VOLTS
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
How I change the blades in the Rs 15 saw machine bosch
To lock a blade in just push the blade in until you hear it click. This is what engages the blade. To disengage just turn the blade clamp until the blade pops out. This will lock it open until you insert a new blade.
Sep 08, 2009 | Bosch Saws
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
How does one remove a broken blade from a Bosch rs20 blade holder
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Saws Logo
35 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
