Question about Canon PIXMA MP520 InkJet Printer
Lcd problem White light on lcd will only show the full colour screen when in about the 60% open position, but this varies. Please help. Thank you. Gábor
    President:
  • 2,306 Answers
Canon is aware of this problem, it's a shop repair to replace the ribbon cable on the display unit.
Posted on Jun 19, 2009
  • 36 Answers
Follow this guide
https://sites.google.com/site/bricolagesetc/imprimante-pixma-520
and buy the spare part (cheap)
http://www.chargeconverter.com/shop/conndev.htm
you have the solution.
Posted on May 24, 2010
Full screen of vertical colored lines, What do I need to check?
Disconnect from computer and try it on another.
might be a video card issue, disconnexion will show if this is the problem. Does it do this when the computor is off?
If it is not a computer issue then try resetting to factory default.
It might be that the screen is going but this is usually evidenced by loss of picture or darkening rather than vari-colour lines
please amend and resubmit query
May 28, 2015 | Hyundai L70N 17" LCD Monitor - 16 ms 1280...
My Samsung Galaxy GT-S5570 is appearing a white screen.this happends after charging,and before opening the phone,,this white colour will go afer sometime.
it sounds to me like your lcd is going out.... if the phone is responsive to your touch but the screen has gone completely white and comes back, it suggests an lcd issue and you should have it replaced
Jan 05, 2014 | Samsung Galaxy GT-S5570
I do not see any image thru the viewfinder of the PV-GS250 Camcorder. I tried to move the viewfinder tube at different inclination and extended lengths, but no light or image appeared most of the time. ...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the vewfinder LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Apr 28, 2011 | Panasonic PV-GS250 Mini DV Digital...
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Blank screen,i.e,white colour with some bluish dots on my mobile
if these blue marks are like ink and afer pressing it seems like it spreading then it means your main lcd is demage and you have to change it.
if its not the case and lcd is completely blue or black
then check the lcd connector if there is any wet, clean it i not, change your keypad flexi.
thank you
shakeel khan
south africa
Apr 28, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Htc cingular8125
Well the 8125 is an HTC Wizard not a TyTn. The TyTn is an 8525 and is prone to white screen problems that are discussed at length on www.XDA-Developers.com
It may be in your case that the internal connector is needing re-seated. To do this yourself is warranty voiding but if you dare there are manuals and guides here:
www.mikechannon.net
Mike
Sep 18, 2008 | HTC TyTN Smartphone
Font discoloration
You may not be running native resolution for the LCD screen.
Open Display control panel and on settings tab, set Screen resolution to maximum right position.
Mar 31, 2008 | Xerox XR619DW Monitor
Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Feb 17, 2008 | Televison & Video
Canon PIXMA MP520 InkJet Printer Logo
428 people viewed this question
old marine
old marine
