Question about Samsung Refrigerators
My samsung RL28FBSI power button is stuck.
I accidentally pushed the button and the fridge shut down. It wont start again. I changed the power option yesterday, today i tried to turn it back by using the power button. Yeah, i should have read the manual before, but now i have a shut down fridge.. Is it common and temporary or is it dead for good?
  • Kert Kaustel
    Kert Kaustel Apr 14, 2014
    Okay.. found the problem - I fried the fuses..
KaeZoo
  • 156 Answers
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Posted on Mar 15, 2007
SOURCE: tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
Posted on May 13, 2007
SOURCE: Mustek DV-3500 DV Digital Camcorder /keeps turning off
Be sure the batteries are not the rechargeable types.  I had this problem when I first got my camera about 4 years ago.  Also, try adjusting the quality settings for the functions.  For example, set the photo function at normal rather than fine.
Posted on Dec 13, 2007
sdmc73
  • 121 Answers
SOURCE: Fridge Wont Turn On
the button is a defrost button
Posted on Nov 29, 2008
  • 6 Answers
SOURCE: keeps turning off
Hey! i had the same problem after i took the computer apart for a clean!!! What happened is that when i took the heatsink off the cpu, the thermal paste had fallen apart a little and i put it back on.... to find computer booting up for about 3 seconds then turning off. i think that when you fire the comp up it turns on the cpu causing it to overheat and shut itself off, just cleaned off old paste and put on some new paste and it fired up! hope this helps you! sorry bout the slight delay!
Posted on Dec 12, 2008
My Samsung CoolTech Model SR-L709EVSS fridge and freezer works for a few days and then goes off by its self and then works again. What could the problem be?
Only time these units completely shut down is when the defrost timer shuts down all power to the compressor and condenser/evaporator motors. Only the bulb works.
If that timer gets stuck somehow that would explain the complete shutdown and mysterious restart later .
Jul 31, 2015 | Samsung Refrigerators
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Sharp tv shut down after about 2 seconds
Could be power supply trouble. It tries to start but can't and shuts down.
Dec 06, 2013 | Televison & Video
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
My model rs2555sl samsung fridge does not start up after power outage.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
Jul 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Can't turn off recording option to play my music
Try pressing and holding down the 'menu' button. It might shut off, but that's okay. Just turn your player on again.
Otherwise, take the back off of the player and slip the battery out. That will definitely shut it off. It's called a 'hard reset'.
Hope you get it working again!
Jan 22, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
Refrigerators Logo
22 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
