Question about Panasonic KV-S1025C
Pages won't feed through scanner. they keep jamming.
2 Suggested Answers
  • 1196 Answers
SOURCE: We have a Panasonic kv-s2055l scanner receiving a
You will need to reset the printer, Hold down the reset and stop button for 15 seconds to reset the printer. Power off the printer after this and allow few minutes to pass before you power on back, if the problm still persist after this, repeat the sequence again.
Posted on Dec 08, 2010
How to fix a paper Jam?
quality of paper and the paper thickness setting may have something to do with it.
Jun 28, 2015 | Brother MFC-7440n Laser Multifunction...
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
Paper Jams - Multiple Pages Pulled - New Rollers Installed
If you have de-stapled papers, the papers may still be held together where it was stapled. Fan the papers before feeding, Check if the '******' roller (the light brown bottom roller) is clean.
S. Mohan
Feb 16, 2010 | Canon DR-7580
Scanner pulls page in to just past the bottom sensor lever
Please ensure that the rollers are clean and within its life span. (Rollers wear out and need to changed after 250,000 pages or as recommended by mfr). FAn the pages before scanning, Ensure the edge is trim with no folds or bends. The griniding noise is because the scanner has picked up more than one page.
S. Mohan. India
May 29, 2009 | Canon DR 3080C Path-Through Scanner
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Canon DR-2080c - Replacing rollers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
Pulls through too many pages at once
In the scanner where it pulls the paper in, there are rubber pads that hinder the paper feed from pulling more then one sheet. Those wear out and need to be replaced.
Feb 06, 2008 | Xerox DocuMate 262 Path-Through Scanner
Doc not feeding
You need a new paper feed tire assembly
Nov 24, 2007 | Ricoh Aficio IS420 Flatbed Scanner
Panasonic KV-S1025C Logo
47 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
