Ferroli problems Boiler was working fine until we noticed a small leak. switched off repaired leak but then when boiler was turned on again it started to show fault A51. This is poor combustion/flue blocked in codes but have checked flue (all clear), fan confirmed as working (powered directly) and |PCB fuse has not blow. Also continuity tests show power to fan. resetting does not work either. anyone got any ideas?? thanks
3 Suggested Answers
  • 9 Answers
SOURCE: fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Posted on May 04, 2010
rachdawkins
SOURCE: ferroli optimax 25 c heating won't come on
Did you ever find out what this was as I have the same problem??
Posted on Sep 12, 2012
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Ferroli boiler
You should have 12psi for boiler to operate properly. Sounds like first you have a leak in your sytem. Second sounds like pressure reducing valve is not working properly.
Dec 19, 2013 | Plumbing
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Ferroli boiler 31 che will not light up when hot water switched on notice in windowe says no ca or no co
are you getting no ca or no co on the time clock? if so change the time clock
May 16, 2010 | Heating & Cooling
I have a alpha cd32 boiler,and i keep having to top the water up within the boiler,so to get hot water and heating again.i have checked for water leaks and nothing is found,however i did check the outlet...
Pressure relief valve - replace
The internal seal gets bunged up with dirt & scale and then leaks water [pressure] to that outside pipe
To avoid draining the whole system, turn off the two central heating taps on the 3/4 pipes and then operate the valve manually and / or disconnect - only a small amount of water will escape / drip to below the boiler
Replace valve and fill as before.
If you think your system needs flushing out - now is a good time
Turn off mains electricity to boiler before starting work
Mar 07, 2010 | Watts 3/4 Pressure Relief Valve
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
