Little Square color blotches
When I leave my PC unattended for a while, these little square color blotches appear all over the screen. If they're on a window, refreshing the window clears them. Even a local refresh, like if there's a mouseover script on a page element in my browser, then mousing over the element will clear the effect from that element, but leave it everywhere else on the window. The worst, though, is the wallpaper. Once the blotches are on the wallpaper, nothing refreshes them, until I reset the wallpaper. What's causing this? A graphics card going south? A virus? Solar flare activity?
    Sergeant:
  • 240 Answers
The most common reason for this is your video card overheating. You did not post the make & model of your computer, but if you have a separate video card installed check it for overheating. Pull the side panel off the computer to inspect. If your card has a cooling fan make sure it is still working (it may have failed) and not clogged with dust. If you have integrated video (the video "card" is part of the motherboard, not separate) check for dust & clogging in the vents. This is especially important if you have overclocked the GPU (video card processor) or the CPU, many gamers do this.
If you are still having problems, I hang out at www.suggest-a-fix.com, a free help forum. Post in there and we can go deeper. This forum is just not set up for in-depth communication.
Posted on Apr 14, 2014
  • 3 more comments
  • ed_4nderson
    ed_4nderson Apr 15, 2014
    Screen shot attached
  • ed_4nderson
    NVIDIA GeForce GTS-450. Stress tested for over an hour and the temp never went above 70. And this anomaly happens overnight, when the computer is mostly idle.
  • Try installing the latest graphics drivers from Nvidia. Dont overclock the card, Overclocking the card can result in glitches if its overclocked even if the temperature doesnt skyrocket. Try unplugging and replugging the card. Otherwise i suggest using a screensaver when the computer is left unattended for more than 10 minuttes.
  • ed_4nderson
    I might be a driver version or two behind. I don't overclock--never felt like it needed it. I will give your suggestions a try, and see what happens tonight.
  • ed_4nderson
    ed_4nderson Apr 18, 2014
    OK... I had the most recent driver installed, but I deleted and reinstalled it anyway. I also disconnected the cables, and pulled the card out of the case, then blew what little dust there was out of the heat sink, out of the cable connectors, and out of the slot in the case. Reinstalled, reconnected, powered on, and have been running for a couple days with no colored blotches. I'm calling it solved, though I'm still not sure what the problem was. I also set up a screen saver, but I don't think it's actually working. I suppose I could try one of the boring ones that came with Win7, but I wanted something a little more... interesting. Oh well. Thanks for the suggestions.
2 Suggested Answers
SOURCE: Mikomi/USB optical mouse has started
Solution found by altering the screen resolution, this brought the mouse under normal scrolling control
Thanks for your time
A Brownless
Posted on Nov 23, 2008
How do I close tabs on this phone
Dear Nancy,
  • Bring the Tabs to be closed on the screen,
  • Look on the upper left side, you will see the number of tabs opened inside a square.
  • With your index finger Tap on that little square with the number(s) inside it.
  • All of the opened tabs will move down leaving a black margin on the top of the screen.
  • You will see an X at in the the Right.
  • Keep on tapping on the X until you close all of the Tabs.
  • Notice that the number inside the square will be counting down every time you close a Tab.
  • After the last tab is closed, you will see a + sign inside a square on the Left of the screen.
  • You must Tap on that + square to open a new tab.
  • You can also message me directly in the Comments Box if you need more help.
Good Luck
JP
Sep 18, 2015 | LG Cell Phones
I have little squares of different colors on my monitor it also seems like my cpu isn't fully booting up. I changed wires and nothing changes I can't see anything so I can't download any virus protection...
try to boot in safe mode by pressing F8 when you turn on the computer use the up/down arrow key to highlight safemode and press enter press enter to select your OS then wait until it loads. during boot up if it still shows the little squares try a known good monitor if it has the little square the video card is busted and needs to be replaced however if ever the known good monitor doesnt have the little square then its the monitor that needs to be replaced.
hope this help
Aug 16, 2010 | Dell Dimension 2400 PC Desktop
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
A Black square keeps appearing on screen, and wont leave
Hi big john
To answer your question;
What you have is closed caption(CC) in text mode.
To remove it ;
On the original remote there is a button labeled CC
Hit that button until you see closed caption OFF
Hope this help Cheers
Apr 27, 2010 | JVC AV-32D305 32" TV
Printing misaligned color blotches, little squares off to the
Are you using genuine inks or compatibles/refills? Have you cleaned / aligned the print heads recently? Does it only happen on the second print? Could be a case of excess ink getting onto the rollers which then get hot and deposit the ink on the next paper coming through.
Also make sure you've selected the correct paper type before printing.
Oct 29, 2009 | Epson Stylus Photo 1280 InkJet Printer
Typing Instructor Deluxe 17 only works on Adminisrator user on family's computer. How do I make it work for all Users?
Hello Misty Moors.
Firstly make sure your logged in as Administrator.
Go to your C: drive
Then PROGRAM FILES
RIGHT click on the TYPING INSTRUCTOR DELUXE 17 folder
LEFT click SHARING AND SECURITY...
CLICK the little square next to SHARE THIS FOLDER ON THE NETWORK this should put a little TICK in the box then click the bottom on the screen to APPLY then OK.
Hope this has helped you out. If so then please leave a thumbs up
Cheers Little Dish Fitter
Oct 13, 2009 | Individual Typing Instructor Deluxe 17.0...
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Samsung A737 water damage..??
the little square that you are referring to is a liquid damage indicator, it will change it's color if the phone is exposed to any kind of liquid or moisture.
Jun 27, 2009 | Samsung SGH-a737 Cellular Phone
Hi, I'm trying to work with a HTML editor creating pages on a web site. When I click on text colors & background colors I get a picture of a square filled with a bunch of smaller box which I assume show me...
He is correct, But you can make the adjustment yourself. Go to the Windows front end screen and RIGHT click, select Properties then the Settings tab. Check that the monitor displayed is the one you are using and then use the controls offered to make adjustments. Be ready to click the cancel button offered in case the screen becomes unreadable. The system will allow you about 30 seconds to confirm any changes you make. If you do not confirm then the screen will revert to the state it was in before you made the changes. This is to ensure that if you are not able to read the screen then it will be put back as it was originally.
Dec 01, 2008 | Computers & Internet
COLOR PROBLEM
Is the pic full? Or is this pink square full and the pic seem squeed?
Jan 03, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
