Question about MPC Computers ClientPro 365 PC Desktop
Change boot order in bios on a client pro 385
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Hi Jennifer. According to my research, these are Intel based PC's When you switch the PC on, keep tapping the 'Del' key to get into the BIOS. If it goes into windows, just restart the PC and try again - if the Del key doesn't work, try tapping F2 as that is also used by some manufacturers to get into the BIOS.
Once in the BIOS, just go through the menus until you find the boot priorities screen and make the necessary adjustments. Hope this helps
Posted on Apr 14, 2014
How do I change the boot order ? It some how changed after I formatted the hard drive it turns on but it wont read install cd or flash drive so can any one help me ?
Enter BOS setup
F1 or F10 Enter Setup at the red Compaq logo or blue HP logo
Boot menu Below is a summary of what is contained on the Boot tab of the BIOS Setup:
  • The order for the bottom process; for example: Removable devices, CD ROM, and hard drive.
  • Boot-time Diagnostic screen
strongly urge to update bios too when possible.
Apr 01, 2016 | HP Compaq Cq60-211dx Intel Celeron...
How do i change the boot order in bios on a clientpro 385 running xp?
Each retail manufacturer sets the BIOS screens up a bit different with different headers, but I can give you a generic "what to look for". Judging from your question, I am guessing that you already know how to access the BIOS setup screen in your computer. There will be a header which may be titled, "boot", "Boot Setup", etc. Sometimes under the old American Megatrends BIOS screens the boot order is found under the Storage Drives section, with other BIOS screens it may be different. I will use a Phoenix BIOS for an example. In general, here is what you do:
1. Restart the Computer and enter the BIOS Setup Utility; this is done by tapping a key repeatedly, usually the DELETE key (but not always).
3. Locate and Navigate to the Boot Order Options in BIOS
4. Make Changes to the Boot Order
5. Save Changes to the BIOS Setup Utility
6. Confirm Boot Order Changes and Exit BIOS
7. Start the Computer With the New Boot Order
I will use an example (I hope this website allows multiple pictures to upload, but here I go):
The first screen will look something like this, with a general posting of your components:
Tap your right arrow key to move this hilight over to the "Boot" header in the top, blue header bar (as below):
Now you have to figure out how this manufacturer set it up; usually guidelines are in the right column to help you, but the general rule is that you hilight the hard drive and (somehow) move it up to the top for the first boot device. Sometimes you hilight "Hard Drive", then press "Enter" and it gives you more options for moving it to 1st boot device. Other times you may be able to directly move it from this screen (above) by pressing a different key. Just work with it and eventually you will figure it out. If you still have the original manual that came with the computer they may (or may not) give detailed instructions.
When you finally get it configured, be sure to save it. This is usually done by pressing F10 key, it will ask you if you want to save settings, press Yes and you are done. If you need additional help, I hang out with a bunch of other techs at the (free) compute help forum, www.suggest-a-fix.com This website is not set up for easy back n' forth communication. Hope this helps you.
Apr 14, 2014 | Computers & Internet
NEC laptop will not boot from disk or USB
just make sure ISO files or DVD you are using to boot with are actually bootable disc for OS ,as for USB booting ,you will need to turn on usb boot on the bios and software needs to be USB software.
and I am not talking about boot order that you have already selected.
check windows 8 software on anther machine and see if you can boot with it
Jan 18, 2013 | Computers & Internet
Operating system not found
is your Hard drive Detected by the computer? check it in Bios if it is detected or not,if it is detected then select first boot device as Hard drive. still you are getting the same problem then there might be chances that your OS is corrupted and you need to re install it.
Aug 24, 2012 | Acer Aspire 4530-5889 Notebook PC
Toshiba Satellite Pro 4600 laptop
Just put the Recovery Disk in the drive and the system should start booting from it. If not, pay close attention to the screen and when it shows you which key to hit to change the boot order or boot sequence hit it. Change the boot sequence to read from the CD drive. This is a temporary change on the boot sequence.
If you want to make a permanent change to the boot order or boot sequence you will need to hit the key that says enter Bios or System Setup and change it there.
Apr 25, 2012 | Toshiba Computers & Internet
Emachine boot from cd
Put the cd in the drive and watch your screen and select the option that allows you to change the boot order if it does not boot from the cd the first time.
You can also go into the Bios or System Setup and set the boot order to read the CD Drive as the first boot device.
Apr 23, 2012 | Toshiba Satellite Pro A200-EZ2204X...
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Installing of windows xp pro with caldera dos
Sounds like your not booting up to the CDROM that you XP PRO disk is in you booting to the hard drive .... what you need to do is go into your bios (usually this is the DEL key, maybe F2, or F10), you will need to look at the screen as it boots up to know for sure... it will say something like Press DEL to Enter Setup. Under the boot menu choose to boot to the CDROM first... it has you put the CDROM and Hard drives in a boot order... ofcourse make sure CDROM is first. Save the Bios usually by hitting the ESC key after making the needed changes and then it will ask you if you want to Save, ... yes you do want to SAVE Changes. Good Luck!!! I hope this works for you!!!
May 11, 2009 | Acer Computers & Internet
How to install of win xp pro X64 in acer aspire 4730Z laptop
Hi there.
Put the disk into the drive, restart the PC and hit F2 as it boots up, this will take you into the bios.
Change the boot order to the CD rom as first boot device, save the changes and exit the bios, the computer will restart and will now boot from the CD drive, just follow the on-screen instructions for the install.
Good luck and thanks for using FixYa!!
May 07, 2009 | Computers & Internet
Open Questions:
See all MPC Computers ClientPro 365 PC Desktop Questions
MPC Computers ClientPro 365 PC Desktop Logo
191 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Bee Santiago
rey francis basa
rey francis basa
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
