How do i change the boot order in bios on a clientpro 385 running xp?
    Sergeant:
  • 240 Answers
Each retail manufacturer sets the BIOS screens up a bit different with different headers, but I can give you a generic "what to look for". Judging from your question, I am guessing that you already know how to access the BIOS setup screen in your computer. There will be a header which may be titled, "boot", "Boot Setup", etc. Sometimes under the old American Megatrends BIOS screens the boot order is found under the Storage Drives section, with other BIOS screens it may be different. I will use a Phoenix BIOS for an example. In general, here is what you do:
1. Restart the Computer and enter the BIOS Setup Utility; this is done by tapping a key repeatedly, usually the DELETE key (but not always).
3. Locate and Navigate to the Boot Order Options in BIOS
4. Make Changes to the Boot Order
5. Save Changes to the BIOS Setup Utility
6. Confirm Boot Order Changes and Exit BIOS
7. Start the Computer With the New Boot Order
I will use an example (I hope this website allows multiple pictures to upload, but here I go):
The first screen will look something like this, with a general posting of your components:
How do i change the boot order in bios on a client - 63649b72-4cb6-43bc-a443-d617d897cc2d.jpg
Tap your right arrow key to move this hilight over to the "Boot" header in the top, blue header bar (as below):
Now you have to figure out how this manufacturer set it up; usually guidelines are in the right column to help you, but the general rule is that you hilight the hard drive and (somehow) move it up to the top for the first boot device. Sometimes you hilight "Hard Drive", then press "Enter" and it gives you more options for moving it to 1st boot device. Other times you may be able to directly move it from this screen (above) by pressing a different key. Just work with it and eventually you will figure it out. If you still have the original manual that came with the computer they may (or may not) give detailed instructions.
When you finally get it configured, be sure to save it. This is usually done by pressing F10 key, it will ask you if you want to save settings, press Yes and you are done. If you need additional help, I hang out with a bunch of other techs at the (free) compute help forum, www.suggest-a-fix.com This website is not set up for easy back n' forth communication. Hope this helps you.
Posted on Apr 14, 2014
Change boot order in bios on a client pro 385
Hi Jennifer. According to my research, these are Intel based PC's When you switch the PC on, keep tapping the 'Del' key to get into the BIOS. If it goes into windows, just restart the PC and try again - if the Del key doesn't work, try tapping F2 as that is also used by some manufacturers to get into the BIOS.
Once in the BIOS, just go through the menus until you find the boot priorities screen and make the necessary adjustments. Hope this helps
Apr 14, 2014 | MPC Computers ClientPro 365 PC Desktop
After booting my clientpro 375 pc I get the error Read Disk Error and commanded to hit ctrl alt delete what is the problem
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 08, 2012 | MPC Computers ClientPro 375 (9557751) PC...
Windows wont boot past the first xp screen restarts again and again in a loop and pressing f8 doesnt work wont le
In that case, place your System disk in the DVD/CD drive after setting the BIOS to CD ROM first boot and boot the machine choosing repair system from the menu.
Hope this helps.
Dec 30, 2010 | MPC Computers ClientPro 365 PC Desktop
I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
Compaq 6310US: Can't get into BIOS
you can try removing and replacing the battery on the motherboard. If that does not work, you will have to look for the reset jumper on the board.
May 02, 2010 | HP Compaq Presario 6310US (DA201A#ABA) PC...
The computer will not start up from boot disk..it keeps starting up normally...it is currently running windows xp but i want to a fresh install it's a 2005 toshiba satellite a100 - ta6
Reboot the computer and go into the BIOS. Make sure your optical device is listed before your hard disk in the boot order. Save your changes and exit. When the machine reboots, it should try to boot from the CD first. It may ask you to press a key to boot from the CD.
Jul 10, 2009 | Microsoft Computers & Internet
I have LG E500 and I want to instal XP. I cant make changes in bios like boot sequence, so I cant boot from cd and therefor I cant instal XP. What should I do?
I don't recommend downgrading your laptop from Vista to XP but...
According to manual, pressing F2 during boot sequence takes you to BIOS and then you can change
the order of the boot sequence in the BIOS. From the manual:
"...set passwords, change the booting order, and add new peripheral devices to the machine."
If you can't find boot sequence in BIOS setup, talk to a support rep online:
http://ca.lgservice.com/index_b2c.jsp
You may need to use a different server if not in CA.
Jul 08, 2009 | LG Computers & Internet
I am trying to reinstall window xp on my conputer but i am getting non system disk error or bios error
seems like the laptop is not starting from the cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter bios thats one way to solve the problem but look for Boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install xp.
here how to work the bios.
http://www.whitecanyon.com/how-to-change-boot-order.php
May 21, 2009 | HP Compaq nc6000 Notebook
I need to install an operating system on a Samsung q1 ultra
Suggest you use an external DVD drive, and put your installation disk in it. Then access the BIOS Setup utility.
In BIOS Setup, find the Boot Order menu. (Generally, along the top headings of the main menu, in BIOS Setup, or located in Advanced BIOS Settings) Set the first boot device to be CDROM. Be sure to Save your change.
This way the handheld, will boot from the installation disk, in your external DVD drive.
Should you be trying to downgrade from Vista to XP, you have to change the first boot device, in Boot Order to CDROM. If not, Vista won't let you overwrite it.
Vista is an upgrade over XP.
Apr 21, 2009 | Samsung Q1 Ultra Tablet PC
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
