Dead KONKA 21 inch TV
I have KONKA 21 inch TV model no K2107SZ02 with its power LED (red) blinks but nothing works. I changed the power regulator IC TDA16846, still nothing. Can u help me on how to make a step by step procedure to reach the problem? and Solve? 10q in advance. DAT
  • Anonymous Mar 17, 2014
    Power is dead. Led blinks green and nothing appears.
    Problem Solver:
  • 4 Answers
Try Check first all the output voltage in the secondary of the chopper transformer if regular voltage acquire. check secondary switching circuit feedback towards the opto isolator and syscon.
Assuming that HOT is OK.
Posted on May 07, 2008
It sounds like the internal power board is almost dead. You could search the Web for a repacement if you beleive that you have the ability to replace it. If not, then there is nothing to do but take it to a repair shop I'm afraid
Jun 23, 2014 | Philips "40PFL5505D/F7 40-Inch 1080p 240...
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
2009 37 inch V7 Konka TV will not turn on
Probable power supply failure. The red power light indicates power is getting to your TV, nothing else.
Jan 09, 2014 | Konka Televison & Video
You have to start troubleshoot the power supply regulator board. Now, it is bad. That's why, no standby LED lights up. If you wish to get some details, check this link. Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Troubleshooting procedure to plasma displays are given in detail.
Nov 11, 2013 | Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
TV is not powering up and red light keeps flashing
I had the same red blinking led problem on my Toshiba Theaterview tv. I resolved by:
- Unplugging the tv.
- Press several times (3 or 4 times) the tv Power button.
- Plug the tv back in and press the Power button once to turn the tv worked!!!
I've had the problem before and tried unplugging the tv for a couple of days and that had also worked, but I this recent solution seems to be faster.
Jul 29, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
