Question about Intel Computers & Internet
Mpc clientpro 385 - Intel Computers & Internet
  • Fix My PC Arizona
    Fix My PC Arizona Jun 10, 2014
    Hi Jennifer Hintz, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
4 Suggested Answers
  • 13 Answers
SOURCE: need an MPC ClientPro 155 power supply
For most computers, there isn't a power supply made specifically for each. Take the power supply out of the computer, and find out what type of power supply it is. Search for a new one on Google or eBay. Solution-givers cannot sell you merchandise.
Hope I helped
~Aeoryth~
Posted on Dec 24, 2009
nonontech
  • 4737 Answers
SOURCE: hello my computer is a
Before we begin troubleshooting, I need some clarifications, What is the operating Systems installed on the Computer? Is it still under warranty? Do you have the Recovery CD?
If it's still under warranty, we shouldn't touch the hardware as it will void the warranty, (this model has 3 years warranty) but if it's not, then we'll do whatever....to fix it.
You may also need a windows CD, it must the hardware issue, but it could also be software issues, so since we haven't tested anything yet, I can't tell you the cause. There are many possibilities and of course, may ways to fix, may take time depending on how much it's been damaged..
Thanks and awaiting.
Posted on Oct 31, 2010
  • 131 Answers
SOURCE: I have an mpc clientpro 385 and I can't get the
This appears to be a generic case. If so there are several ways it may open up.
First, the most common is to remove two or three screws in the back along the edge of the side panel where it turns and goes over the back of the system. I assume you've tried that. If you are certain that the side panel is of this type you may need to take a flat screw driver and slide it between the panel lip (the part that folds around and through which the screws are inserted) and the system frame. Slide it in and turn it to "pop" the panel. Once near the top and once near the bottom should do it.
If you don't have that type of side panel there are three other options. First, the top of the case may be held in by a screw in the middle of the top-back. If there is a screw at the back at the very top in the middle of the edge, remove it. Slide the top toward the back (it should go back about 1/2 inch) and lift it off. The side panels then lift straight up and out.
Second, you may have a latch in the middle of the back next to the side panel lip. Depress it and slide the side panel off (this is usually something you see only on Compaq's and other name brand computers, not generic).
Finally, there are some systems which have a lever at the top back of the system that you pull back to spring the side panel. If the panel is stuck, pull the top lever back and use a screw driver so pry the side off from the top...it tips back from the top and then lifts out after you pull the lever.
Hope all this helps.
Posted on Jul 18, 2014
Mpc clientpro 434 manual
Try searching on google, I found a website when I searched.
Link: ClientPro 434 All In One Manuals
Hope it helps,
JD
Apr 18, 2014 | Computers & Internet
Change boot order in bios on a client pro 385
Hi Jennifer. According to my research, these are Intel based PC's When you switch the PC on, keep tapping the 'Del' key to get into the BIOS. If it goes into windows, just restart the PC and try again - if the Del key doesn't work, try tapping F2 as that is also used by some manufacturers to get into the BIOS.
Once in the BIOS, just go through the menus until you find the boot priorities screen and make the necessary adjustments. Hope this helps
Apr 14, 2014 | MPC Computers ClientPro 365 PC Desktop
Pins in power adaptor will not insert into place where adapter is to plug in
HI
The port of the power adapter for your MPC Computers ClientPro 414 All-In-One PC MUST be the same below
Dec 07, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Where do i get the ethernet driver for my mpc clientpro 414
ClientPro 414 Ethernet Driver >>Click here to download Windows XP Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN DriverClick here to download Windows XP x64 Edition Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN Driver
Oct 21, 2011 | MPC Computers ClientPro 414 All-In-One PC...
RECOVERY dISC
you have to goto your pc manufacturer site to get the recovery disc....
Dec 27, 2009 | MPC Computers ClientPro 365 PC Desktop
Need an MPC ClientPro 155 power supply
Hope I helped
~Aeoryth~
Dec 16, 2009 | MPC Computers ClientPro 155 PC Desktop
I need IDE adapter for MPC 414. Hard drive to MB,fits in caddy. Appears to be an edge connector?
You can contact Patrick Albright at Tangent, 1-800-342-9388 x1772 they are carrying the MPC parts these days. I just talked to him.
Aug 21, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Powers on MPC comes on screen. One short beep. Hard drive light and another light flicker, then it hangs.
PUT INA WINDOWS DISK OR THE SYSTEM DISK THAT CAME WITH UR CPU AND RESTSRT,,, FOLOW THE DIRECTIONS
May 11, 2009 | MPC Computers ClientPro All-In-One PC...
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
