Question about Whirlpool GU2400XTP Built-in Dishwasher
Gu2400 Whirlpool dishwasher stopped working and wont turn on
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Posted on Dec 23, 2007
  • 188 Answers
SOURCE: whirlpool gu2400 dishwasher
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
SOURCE: how do you reset the whirlpool gu2400 xtp83
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: Leaking door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Have lost my manual. Cannot remember when putting in the dishwasher salt, should the cap be showing the red spot? Not sure at what point you put in the salt? Thanks for your help
Not sure if you are referring to the dishwasher detergent or the rinse-aid.
The two items are mentioned on pages 13 and 14 of the user guide for GU2400 model.
Hope this helps. Cannot find any mention of salts or cap red spot.
Jun 28, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Leaking door
Leaking Dishwasher
heatman101
Jun 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool dish washer model #Gu2400 -dishes are clean but clean light keeps flashing
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Whirlpool Dishwashers
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Jul 29, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
Quiet Partner lll won't start
You really won't know until you replace the control board. It does sound like the board to me.
Feb 07, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400 dishwasher
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 05, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool gu2400 clean light is blinking 7 times
Dec 23, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
GU2400GTX
electronics fail most often when new. would not be surprised to see you have a logic board failure.
a new unit should not have any issue that would contribute to a malfunction, so looking for door switch problems or motor problems seems like a waste. call the service center for the unit.
good luck
mark
Apr 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400
Yes I have a similar problem... GU2455XTSQ3 whirlpool gold. Hangs up at 52 minutes accompanied by a loud humming that lasts for 1/2 hour to 45 minutes? Then for whatever reson the cycle will continue and complete! This just started 6 months after purchase. Any ideas?
Mar 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
18 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
