Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
DELONGHI PERFECTA ESAM 5400 isn't descaling
Water isn't passing. It makes an effort but nothing happens. I follow the procedure to descale but it doesn't work. Press P, turn to descale symbol, press ok and it begins to flash. Press it again and descale light and cafe ground container flashes alternating between them. Press it again and engine start under effort and nothing happens. no water passes
kram26
  • 544 Answers
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Posted on Mar 21, 2009
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
espressonist
  • 1711 Answers
SOURCE: I have a delonghi esam 3000. When I plug in the
Try to turn the steam knob to off postion and the switch off and on again. If the light insist that means that the steam micro-switch which is activated by turning the knom is either stuck in on position or is faulty and need to be replaced.
Posted on Sep 08, 2010
SOURCE: There is a flashing warning
Mostly it is just a very unreliable product. I am on my 3rd replacement after only 14 months.
Posted on May 24, 2011
SOURCE: I have a descaling issue with my DeLonghi
It means a half of a full revolution (180 degrees), Not a half of a knob turn (90 degrees). 90 degree on the ESAM3300 doesnt do anything. Turn the knob a full 180 degrees to start the descaling
Posted on Jul 02, 2011
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
Tip
How to descale espresso machines.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Here is a basic generic picture of a espresso system of how they work.
I hope this helps. Feel to contact me for addition questions. Thanks Mike
on Jul 26, 2011 | Coffee Makers & Espresso Machines
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Jun 29, 2011 | Microwave Ovens
How do you descale the machine,as we have no manual
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
How to clean coffee machine properly? i was given one and want to ensure that it is save from "everything" so i can start using it.
Jun 09, 2011 | Coffee Makers & Espresso Machines
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
