Question about Blinglights 1998 1999 2000 2001 Isuzu VehiCROSS Angel Eyes Off Road Lighting Kit Halos Driving Lamps Brush Bar
Engene not start - Blinglights 1998 1999 2000 2001 Isuzu VehiCROSS Angel Eyes Off Road Lighting Kit Halos Driving Lamps Brush Bar
Light Engen comes on
Pull up the error codes and post them here. Thanks.
Apr 09, 2014 | 2001 Toyota Corolla
Mercedes c180 kompressor, 2003 model, 271 engen. I was when it flashed a red light on the dashboard saying oil level too high reduce. Then suddenly the engen stopped. I tried to crank it again and it...
Have you checked your oil level? Is it over full on the dipstick? What does the oil look like - clear or milky? If milky, you may have had a head gasket failure or crack in the block/head that allowed coolant into the crankcase. If you kept running the engine after this, it may very well have seized. The timing chain can't get 'too tight', so that is not your problem.
Use a breaker bar with the appropriate sized socket and see if you can manually rotate the crankshaft pulley. If not, your engine is going to need some serious work (or replacement).
Jul 01, 2017 | Mercedes-Benz C-Class Cars & Trucks
Dodge 300van---318 engene 1970
Fuel filter has nothing to do with a misfire
That is a vacuum leak,ignition problem,
timing or mechanical timing issue
Mar 12, 2013 | Cars & Trucks
Engen light comes on engen loseo power
Make model and year, and have you had the computer scanned for trouble codes yet ?
Feb 01, 2013 | Cars & Trucks
Jonh deer engen dies when when break relices
sounds like the safety switch for the clutch/brake pedal is bad
Jun 27, 2012 | Garden
01 ford expedition. its hard to star all the time, i can run only if i hit the gas pedal if idont the engene is gonna die but once the idle kick that means its good
may be low fuel pressure at start up. Try this, turn key to ON and wait 5 seconds for fuel pump to stop humming. Then try starting. If it starts up faster, you have a bad check valve in the fuel pump, change it. It's in the fuel tank.
Slim chance it could be the fuel pressure regulator on the fuel rail with the injectors. very seldom fails.
Finally, your cold fast idle circuit is not wokring right. Clean passages.
Aug 30, 2011 | 2001 Ford Expedition
Check engen turnd on. car lacks power back to normol after 20mph
Probably a spark plug! Check em all out and if old replace with new ones gapped properly!
Dec 07, 2009 | 1993 Cadillac DeVille
Jenn-air fridge freezer not working
you need to buy gas or take it to the engeneer. but the engeneers cost alot so, buy gas.
Oct 31, 2009 | Refrigerators
Blinglights 1998 1999 2000 2001 Isuzu VehiCROSS Angel Eyes Off Road Lighting Kit Halos Driving Lamps Brush Bar Logo
41 people viewed this question
Top Blinglights Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Blinglights Garden Expert? Answer questions, earn points and help others
