Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Machine status p-22
Plz help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Your color registration is off. Most likely a laser unit has gone bad. If its the laser unit, it will probably cost more than the machine is worth even if you find it used. It may just need a good cleaning and calibration by going into service mode. You should still be able to run the machine.
Posted on Nov 14, 2014
  • Anmol Gupta
    Anmol Gupta Nov 30, 2014
    how to do calibration in service mode i can open the service mode but then didnt understand what to do
My Kyocera fs-1118MFP is cutting off top margin of all documentscopy or print. How do I fix, plz help.
I don't know that machine but generically, the description suggests a faulty drum or fuser unit...
How many prints or copies since either or both were changed, please?
Sep 02, 2016 | Kyocera FS-1118MFP Laser Printer
Softwares that can reset my counter printer
    http://www.samsung.com/us/pdf/SCX_6345N_Brochure.pdf
    Press the Machine Setup button on the control panel. The screen then displays two menus:
    1) Machine Status: This shows the supplies life, billing, counters and reports.
    2) Admin Setting: This lets you set the advanced setup to use your in depth or conveniently.
    http://www.manualsprinter.com/manuals/samsung/Samsung_SCX-6345N.pdf
    Page 22
Jan 08, 2016 | Samsung 6345 Copier SCX6345 Printer
I TRY TO PRINT TEST PAGE ON CANON SP200SPX BUT NOTHING HAPPENS WITH THE PRINTER. ON MY PC, STATUS MONITOR SHOWS COLLECTING PRINTER STATUS AND THEN AFTER A FEW SECONDS SHOWS MESSAGE "PRINTER NOT...
plz try by reinstalling the drivers,if the problem is not solved then scan you pc with a updated antiviruse software.if the problem is there then change the usb cable and try with another usb slot.
If problem is not solved then plz try in another system. if problem is not occuring in the other system then your operating system is having problem otherwise your printer needs servicing
Aug 26, 2010 | Canon S200 InkJet Printer
How do you fix Status Code LL-22
‘LL-22’: High Voltage Transfer failure. I would suggest calling your local Xerox tech.
Jun 24, 2010 | Xerox 8830 Copier
Euro-vox max v box
key 0 .7F CD 76 82 BB 22 0A C5
key 1 .97 9B 22 E0 5B 13 B1 C7
Jan 01, 2009 | StarTech.com StarView SV211K 2-port KVM...
. hpdeskjet4180 -not working inspite
plz reinstall the drivers for it, then check the ink status
Plz post for futher help
Jun 26, 2008 | Office Equipment & Supplies
Status deleting
plz check your pc for viruse(update the anti-viruse software and disable the system restore) then uninstall your printer and reinstall your printer.Plz post your findings
Jun 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Trouble code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
May 06, 2008 | Sharp AR-160 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
146 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
