Question about Maytag EPIC MFW9700S Front Load Washer
My maytag mfw9700sq1 was all of sudden leaking. Opened it up and what looked like a gasket was kind of crumpled and a round clamp of some kind was exposed....how do i reseat this gasket and i guess use this clamp to keep it in place
    Problem Solver:
  • 5 Answers
Ddrtrt
Posted on Jun 18, 2009
Looking for agitator parts for 909278 maytag style Master
There appears to be variations of this model. Here is a link to one company who may have the parts and assistance you are seeking:
Here are the model number variations:
  1. MFW9700SB0 - Washer
  2. MFW9700SB1 - Washer
  3. MFW9700SQ0 - Washer
  4. MFW9700SQ1 - Washer
http://www.appliancepartspros.com/search.aspx?model=mfw9700s
Jul 21, 2015 | Maytag EPIC MFW9700S Front Load Washer
I disassembled doors front and back and found a pin hole leak in the tub tonight. Looks like a 1mm hole in bottom left of tub (when looking from back). I ran a cycle and 100% certain water leaking from...
check that there is a small tube in the area as it is around that spot that the pressure hose goes up to the water level selector switch
otherwise use a short metal thread screw with a fibre washer under the head to plug the hole
you can get screws as short is 3/8 to 1/2 " and thick in diameter to fit into the hole
too long and it will bind up on the wash tub
Nov 21, 2017 | Maytag EPIC MFW9700S Front Load Washer
I have a 30 year old top loading washer Maytag 7710. Leaking.
Sometimes the drum gets a hole in it from rust. That can be fixed with a waterproof sealant available at most hardware stores. That is also where you might find a "hose clamp"; if not, you can get one at any auto supply store.
Make sure you get the right size. The best clamps are tightened with a screw driver. Neither of those items are expensive.
One of the two things I suggest should take care of the problem.
Jim Hart
Jun 20, 2010 | Maytag Washing Machines
Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag mdb7100awb dishwasher is leaking from the bottom right corner. starts to leak almost immediately upon starting it. I then opened it and found that the entire tub is filled with water, looks like it...
take off the bottom panel there are 4 screws you got take they are 1/4 inch screws  once the panel is off turn on the dishwasher and see where exactly the leak is coming from
Jun 07, 2009 | Maytag MDB7100AWB Dishwasher
A leak under the washer. model Splendide wd802
well there is a seal between the tub of the washer and the transmissition you cant see it utill you take it apart so just fill the tub with water and dont let the pumps or motors run if you are getting water from around the transmition that is your problem i have a maytag and that gasket cost just under 70 bucks so much cheaper than buying new washer
Mar 31, 2009 | Washing Machines
Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Jan 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Dec 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
469 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
