Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Leak We have a top freezer roper refridgerator. It is leaking into the fridge part. we thought that it was the gasket around the fridge and that didn't help.. it is filling the lower part of our fridge and leaking onto the floor. the freezer is still cold and it is still making ice etc.. what could be the problem
  • 2 more comments
  • Anonymous Nov 22, 2007
    Water is leaking apparently from the freezer part
  • Anonymous Feb 23, 2008
    same problem
  • crzypopmac May 29, 2008
    Same thing, lousy Roper Fridge, bartely 2 years old, only last week the bottom of the fridge was full of water, wiped it out and it started over again, thought the door was not shutting properly...NOT...door seems fine. Thought it might be the ice maker, leaking into the fridge area, but not so sure now, will ckeck out the various suggestions. Used to have a Sears-Kenmore for almost 30 years, ran fine, until the compressor blew, the ice maker was lousey, but got to the point where I could take it apart and put it back together in 30 min (before the stuff started to defrost).
  • Anonymous Jun 02, 2008
    Although it is supposed to be a "self-defrosting" model, when mine began to leak I found I had to get in there with a blowdryer. The drain hole (which is connected to the tube to the drain pan) was iced over. Hopefully defrosting the freezer will do the trick!
Remove the interior panels of the freezer. Then use a some thing rigid to remove the ice from the bottom of the freezer. Next use a gravy baster with BOILING HOT WATER to clear the hole in the back under the defroster. Next pull out the fridge away from the wall and remove the back cardboard panel and look for the drain tube that looks like a "J" cut off the bottom of the  "J" this will help with draining. Reassmble and make sur drain hole is clear in freezzer. Next if you still have problems Find the self defroster in the freezer and CAREFULLY wrap a bare copper wire around it and stick down the drain hole to keep it clear. Then Reasssmble the freezer and you should have no problem.
Oh By the way most cooleing problems are FROM DUSTY COILS.  Find your coils Either on the back or under neath the fridg. and clean them off and your compressor will last for years
Posted on Jan 30, 2009
Removing the panel, thawing with a hair dryer and clearing the ice from the drain hole worked for me today. Before I replaced the panel on the back of the freezer I noticed water was standing in the drain tray. I got out my level and viola the refrigerator was not level. Once level the water seemed to drain. If the water does not drain completely from the drain tray it may build up overtime and eventually ice over the drain hole. Just a thought.
Posted on Jan 14, 2009
OK, I took the tray out of the freezer, found the drain, and poured hot water down it until the ice melted, also tried a hair dryer aimed at the metal tube, after awhile it started draining on its own, so far the problem has not repeated itself- crzypopmac
Posted on Sep 16, 2008
  • crzypopmac Jun 26, 2014
    Turns out they sell an after market fix, but why they dont install it prior to leaving the factory is stupid, what happens is water gets in the drain tube and freezes, so the fix is a small metal part that hooks on the defroster coil and trnasfers heat to the drain tube, better solutioon, a 6in bit of copper wire wrapped aroubnd the heating coil and the other end inserted in the drain hole, cheaper too!
By now you must have this fixed but for the next guy here is what I did. My model has no access from the back except for the very bottom. Remove cardboad back cover and on the left side there is a white plastic hose. Use compressor to blow air up it to remove ice and or clog. Before doing this remove all items and shelf from freezer and remove the three hex head screws from the back panel. If your drain has been clogged a while there may be some ice to break up and remove so the back panel can come off. Behind this cover you will have access to the small stainless steel drain pan. Poor hot water on it to melt ice as best you can then blow air on the hose to knock out the clog. At this time I do not know what caused the icing so if it happens again I'd appreciate someone else stepping up to explain how the drain line stays warm enough to aviod future icing.
Posted on Sep 15, 2008
Tell ya what you do, take out bottom tray of freezer, Ice maker (if you have one) then take back panel off freezer. Right under the coils you'll see a drip pan. Use hot water to defrost the ice off of your drip pan till you make out the drain hole. Defrost this area as much as possible. Get in behind the back of the refregerator and take the back panel ( usually cardboard)off where you can get to the drain hose hanging right over the drain pan. Using an air compressor force air up thru the drain hose and 99% of the time you blow what ever obsticle there is out.
Posted on Jul 15, 2008
I think if you take the tray in the freezer out you can see the drain. Mine had a piece of plastic covering the hole , which kept it from draining properly. The tray is held in by two 1/4 " bolts.
Posted on Nov 06, 2007
  • 27 Answers
Drain line is clogged. when the frig defrosts the water drains through a tube down to the bottom of the frig near the compressor where it evaporates away. look on the back of the unit to see if the tube runs down the back. follow it to the end. you need to blow backwards through that tube. let me know if this helps.
Posted on Nov 01, 2007
Where do I find the drain I have water leaking into my refridgerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer is over freezing/ice-ing up behind the board {where all the wires/fans/stuff is} thus not keeping fridge or freezer as cold as it should be.
You fridge has a broken defrost controller or a broken heating element.
Go to Roper online to find your parts and then see if you can buy them either at applianceparts.com or ebay. These are good cheap ways to get your stuff sent directly to you!
Then, unplug the fridge, thaw it out. And while its unpowered and thawing replace the two parts. Refer to your units parts diagram for parts locations. The controller should just be hiding down underneath or in back and the defroster heating element is usually under the freezer.
Good luck and be careful!
Feb 08, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
Water is pooling in the bottom of my roper refridgerator.
check door gasket all the way around , check water line inside frige behind crisper drawers
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Refridge leaking water inside it...
Should be a little drain hole in the bottom rear of the fridge. Use a pipe cleaner or somthing similar cos it,s probably blocked. Quite a common problem.
May 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Freezer leaks water from top to the refridgerator
Has this got an ice maker installed. Thats where I would be looking for a problem.
May 06, 2009 | Roper Refrigerators
Roper refrigerator--water accumulating in bottom of fridge
on some refridgerators the plug at the bottom inside either turn out or lift up,be gentle either way,probably plugged just under it
Apr 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
304 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
