Question about Humax Televison & Video
Problem with Humax 5400Z power supply
No supply receiver will not come on
    Habit-Forming:
    New Friend:
  • 129 Answers
Satcure can provide a repair kit for this model:
http://www.satcure.co.uk/tech/humax.htm
Posted on Jun 06, 2014
I only have one scart outlet on my tv my ariel is in the wall and mthen into my tv but its just picking up tv programmes on my humax recorder and not through my tv
The aerial should first go to the Humax, then from the Humax to the TV. Make sure power-saving is turned off on the Humax, otherwise it will not pass the aerial signal to the TV when the Humax is in standby.
If ypou want to use Humax power-saving, the aerial must be split so that one feed goes to the Humax and another to the TV.
May 19, 2016 | Humax Televison & Video
Screen is grey with dots. No message. Originally stalled on picture. When restarted only grey withe dots came up. Humax only 18 moths old
The later build Humax products have some first models good and now oft poor ventilation slots that is better to open secure to release better the warmth. first
Second is the power supply capacitors there are not much capacitors insite that braun power supply i have today repaired a humax 5000c look the pictures the vent slots are now open and 6 capacitors are replaced (only neccesary for power supply) what was 10 v is now 25 v and 25volt are now 35 volt parts 680 mf replaced for 1000mf 82 mf for 100 mf
Thats all what is neccesary to repair the humax POWER SUPPLY
BUt if that your model is not 24 months old you will have warranty on hidden defects because its to young . because it could be another defect but 88 percent its the powersupply .
Apr 21, 2016 | Humax Televison & Video
600t appereance on the diggital screen humax irhd-5oooC. now have no tv picture. The remote also does not work and all connections are good as well as the batteries. What to do?
To check the remote, use a digital photo camera, not an iPhone, because it has an IR filter, to see it transmits codes, when you press a button. When the remote does work, you have to fear the Humax is defect. Just check if the Humax gets power. Power form the mains, but also if the cable is still firm in the socket.
Mar 10, 2015 | Humax Televison & Video
Its stuck on standbye
If it is a few years old, the most likely cause is failing PSU (Power Supply Unit) capacitors. These are replaceable by a competent electronics repairer.
For a more accurate answer, the model number would help.
Mar 15, 2014 | Humax Televison & Video
My humax has gon dead
Check the fuse at the main power supply regulator. If found burned, check and replace faulty component/s at the power supply regulator section. If you are not handy, contact any experienced service technician.
Jun 08, 2012 | Humax 22 in. LCD TV
How can i fix the humax IR free the reciver not working no LED power light
when pluged to a power supply it click but does not display power
Oct 14, 2010 | Humax HFA100 DTV Receiver
Humax PVR9300t keeps freezing, have received instructions from Humax on resetting PVR to basics which hasn't solved the problem. Is now starting to freeze during recordings.
Apparently there is a new Humax software update which will be released on 3rd March 2010 - leave your box on standby that night & hope for the best.
There are a number of us with the same problem. Curently the only solution is to power cycle the box (turn off & on again from the switch at the back)
Nov 18, 2009 | Samsung SIRS4120R Receiver
The humax keeps on messaging that the antane cable is short circuited. is this an internal problem or a problem with the aerial itsefl
The Humax PVR-150T will definitely have problems using an indoor set top aerial; this is true of almost all Freeview receivers. Freeview signals are typically hundreds of times weaker than terrestrial transmissions and if you've managed with a set top aerial so far it's been working more by luck than design. I find that most set top aerials are so badly made that they're often faulty when new, but as most tend to flogged cheaply at markets and car boot sales the supply chain has no incentive to improve the product.
There has recently been a national Freeview retune, to complete this correctly your box needs the kind of solid and reliable signal which you cannot get with a set top aerial. Some receivers had compatibility issues with the retune and in many cases manufacturers broadcast OAD's (Over Air Downloads) to update the firmware in the boxes to be compatible. OAD's almost never successfully install via set top aerials.
There is an official list of Freeview devices which are known to have problems with the retune; unfortunately it has not proven to be a comprehensive list. The Humax MG-TU1 is one of those which have had problems and from memory it's closely related to your Humax PVR. The official advice is that you contact Humax directly on 0870 247 8800, but they'll probably instruct you to test your box using the aerial system it's designed to use before they'll be interested in offering further assistance.
Nov 05, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Humax 5400 satellite receiver ,power suppl problem
Dear Robert...
I think the problem with my humax 5400z is similar to yours.
Both 5400 & 5400z have the same power supply unit.
I just solved it this evening by changing C9.
It's a 1500 μF 10V electrolytic capacitor. Be careful not to reverse the polarity my friend.
If you have problems to find the capacitor just e-mail me at rel@link.net and I'll send you pics showing the location of that C9 capacitor on tthe psu board.
Hope this could help you.
Good luck.
Ramez Lebbad.
Dec 04, 2008 | Audio Players & Recorders
Televison & Video Logo
85 people viewed this question
Top Humax Televison & Video Experts
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
