Question about Samsung Televison & Video
DEAR SIRThis is regarding SAMSUNG 3D SMART TV 46" series 6400 model no UA46F6400DK which was purchased from your store on 10th december 2013.Regarding this I have spoken to MR. SANTHOSH on 10-04-2
Samsung 3D SMART TV 46" UA46F6400DK
HDTV GURU
  • 261 Answers
SOURCE: picture takes a long time to come on
Need more info on the unit.
Model, Serial # and Version # on side of unit. It sounds like you either have powersupply problems or cold solder joints in the power supply. Resoldering board may solve your problems.
Let me know, Have a good day. Jay
Posted on Jan 31, 2008
skotkolr
  • 558 Answers
SOURCE: 2 year warranty
the Majority of problems on this and all other LCD TV's are capacitor problems the power pack needs smooth power to work correctly however the warranty should be valid and you need the proof that you bought it and you need to know who to contact about the 2 year warranty it may be Emerson you need to speak with not Walmart. I would contact them next(Emerson), or whom ever the third party repair service is that will cover the Warranty.
hope this helps
Posted on Apr 07, 2009
roety
  • 585 Answers
SOURCE: Samsung 46 clicks takes 45 sec for picture
Hi my name is Eric,
I hope I can help you with your issue ,
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound .
Great that its under warranty
These Samsung LCDs have problems with the power supply capacitors going bad, a servicer will charge between $200 and $450 to repair it replacing either the capacitors or the whole board.
here is a DIY (do it yourself) solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on to.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and MF and Volts values)
Samsung uses mostly 1000Mfd at 16Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
Im am posting a photo of some swollen caps on a board so you know what they look like;
best of luck to you
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 07, 2009
Testimonial: "I talked with the technician who will be coming with the new power suppy this week to repair it in home. Good job & thanks!"
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 541 Answers
SOURCE: SAMSUMG 46'' LCD TV MODEL LN46A530P1FXZA PROLEM
Check for bad capacitors in the power supply. The capacitors will be bulged on top. Typically there will be 3 or 4 caps with this problem. Thanks for using fixya.
Posted on Jan 23, 2010
Tip
How to find out the series number and model code of a Samsung Smart TV
1. From your Smart Remote press the Menu button
2. In the menu displayed in the TV , select the support option
3. Select Contact Samsung option in the Menu
This displays the Model number / code, firmware version and other details of the TV. Scroll down the popup menu to view other details of your TV.
on Jan 09, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Vertical green lines on the feft
The tcon board or the mother board is faulty. can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 27, 2016 | Samsung 46" 7500 Series Full HD Smart 3D...
How do I fix a washed out picture problem on my 46 inch samsung series 7100 led tv?
The common cause of this issue is down to a board that connects the screen to the main circuit video board of the tv. It is usually located top middle of the tv and has 2 white ribbon type wires coming from the top and is normally covered in a metal shield.
There will be a part number on the circuit board, this will be the one to find online which matches your screen. If you got an identical tv with another fault, it may not have the same part as each combination is different depending on the manufacturing line or part revisions.
The part you are looking for is called the T-Con board . Hope this helps.
Apr 02, 2016 | Samsung 7100 Series UN46F7100AF 46" LED...
Samsung LED 50 LED smart TV series 6400 is turning off and on over and over, Power supply repair?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 13, 2016 | Samsung 50" 6400 Series Full HD Smart 3D...
Samsung 6400 3d 55 settings
SAMSUNG series 6 6400 User Manual Download the user manual to this TV by this site. It has all details.
Electro help
Dec 11, 2014 | Samsung 6400 Series UN55F6400AF 55" LED...
Samsung f6400series 46" smart switches off and on when i plug my 1tb hard drive in why does this happen and how do i resolve this?
I am assuming you are using the USB (HDD) port and the hard drive has its own power adapter connected. The actual menu operation is provided in the user manual available from this site and USB connection with HDD is described under Photo and Media.
40 F6400 Series 6 Smart 3D Full HD LED TV UE40F6400AKXXU Support...
Sep 05, 2014 | Samsung Televison & Video
Why does my JBL sound bar connected with the optical cable not get any sound from my samsung ue46f6400
You may need to select 'external speakers' in the audio setup.
Here are the steps:
http://www.samsung.com/us/support/howtoguide/N0000058/12807/153493/UN40F6400AFXZA
Menu / Sound / Speaker Settings / Speaker Select / select External Speakers
May 18, 2014 | Samsung 6400 Series UE46F6400 46" LED TV...
Televison & Video Logo
43 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
