How do you refit the inverter lead back into new laptop screen
How do you refit the inverter lead to screen
    Top Expert:
  • Computers & ... Master
  • 23,221 Answers
You put it back as you took it out. Two plugs.
Posted on Apr 14, 2014
Pink screen
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter (IF Used)
4) LCD screen
Diagnose to find out.
I need the laptop manufacturer name, and model number.
Model number can be found on the Bottom of the laptop.
Post back in a Comment.
A) Graphics chipset:
An external monitor is used to check, and see if the display is also pinkish on it; or it is OK. Info posted I need, I will detail this procedure out step by step.
Display good on external monitor means graphics chipset is OK.
(Mounting is usually the problem)
Means problem is screen Inverter (IF used), or Video Cable, or LCD screen.
B) Video Cable:
The Video Cable connects to the motherboard, in an area under the Keyboard, or under the Switch Cover.
(Depending on laptop design, Switch Cover may be an integral part of Palm Rest Cover)
From there it leads under, or close by the left Hinge; and then goes up into the Display Assembly.
IF, a screen Inverter is used, the Video Cable has a separate small cable that branches off; and connects to one side of the screen Inverter.
The main part of the Video Cable connects to the back of the LCD screen.
Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pulled on, and/or pinched.
This can lead to a loose connection at the motherboard side, or LCD screen side. (and/or screen Inverter, IF screen Inverter is used)
Can also lead to a damaged Video Cable. (Stretched/Broken wires inside it)
This can cause a pinkish screen.
C) screen Inverter:
With Backlighting that uses CCFL/s for a Backlight, a screen Inverter is used.
(Cold Cathode Fluorescent Lamp)
For Backlighting that is LED, a screen Inverter MAY, or MAY NOT be used.
(First design LED backlighting seemed to. Later design LED backlighting, does not. Light Emitting Diode)
A screen Inverter is used to convert the power (Electricity), from the laptop; for the LCD screen and Backlight.
Screen Inverter going out, can cause a pinkish screen.
D) LCD screen:
Graphics chipset is good, Video Cable connections are good; no damaged Video Cable, screen Inverter is good (IF used); problem is LCD screen.
Awaiting manufacturer name, and model number.
Regards,
joecoolvette
Apr 30, 2013 | Computers & Internet
Where can i find the process to change a D410 inverter
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Apr 07, 2011 | Dell Latitude D410 Notebook
Toshiba satellite a300 laptop display problem screen black, no display at all.
You laptop either needs a new Cable from the Motherboard to the Screen, a new power inverter, or a new screen. Most commonly, I have seen the video cable get smashed between the hinges/plastic case, and this causes the wires to break apart, leading to a black screen.
Here is the power inverter for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,Inverters.aspx
Here is the video cable for your laptop: http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3392&zenid=7903c7a1a62c4c2cbfef6ea30865373c
Here is the LCD screen for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,LCDs-Displays.aspx
If the display comes back, slightly, when you lift the display lid up and down, this would be a sign that your cable is bad. If you get no reaction from opening and closing the lid, you may have a bad inverter or screen. It is most commonly the inverter or the cable.
If you have a spare monitor, you could plug it into the VGA connector on your Laptop as a temporary solution. If after plugging the monitor in, you get no display, try pressing Fn + F5.
Mar 09, 2011 | Toshiba Satellite A300-0CF035 Notebook
No back light
if you can vaguely see the windows loading screen , then your inverter has gone, they are located in the middle bottom of your screen, pretty easy to replace, just make sure you get the exact one for your laptop as using one willy nilly from another laptop can cause more damage there are two leads that plug in to either side of the inverter and usually a couple of screws holding it on
If you find this useful please vote for me
Feb 23, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
BLANK SCREEN MAYBE THE VGA CARD? pLEASE HELP
Hi first thing to do here is to see where the problem lies. use a vga / monitor lead from your laptop to an external monitor or lcd/plasma tv in pc mode and by pressing fn and your monitor switch key think its f5 you should be able to determine if your screen is at fault, a common problem is the screens inverter or backlight bulb, if you manage to get an image on your external source then you its sure to be screen related wether it be the inverter/backlight/or even your internal screen lead this process can save money and time, you would then need to test the inverter to see if its this, the inverter is normally the cheaper option as the backlight can be a long tricky process.
I hope this has helped please rate :)
Feb 23, 2010 | HP Compaq Presario CQ50-110US Laptop
CCFL OK but no display
LCD panel. i have several Toshiba laptop with bad LCD.
Nov 04, 2009 | Toshiba Satellite LP154W01 Notebook
My new Satellite M305-S4910 is experiencing a monitor flickering. What can I do to stop it flickering?
Remove the power strip above the keyboard and the keyboard and remove the bezel on the LCD. This will give you a clear view of the wiring leading from the screen to the motherboard. Look for a loose connection or rubbed or frayed wiring. Also, a lot of video problems are from the cable getting loose that runs from the back of the screen. This is a flat cable the fits in a socket on the back of the screen.
Here is the lcd removal duide for your laptop....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
Sep 22, 2009 | Toshiba Satellite M305-S4826 Laptop
Laptop screen inverter issue (Toshiba Satellite A205-S4587)
Inveter issues are a common fault on laptops both new and old. In many cases it is up to the individual to decide if the laptop is still going to fulfill thier needs for the next few years if it is repaired or sold to provide some funds towards a new laptop.
I have not seen any special cooling products for inverters. I have seen laptops used as desktops with the screens left running for weeks on end which is not the primary purpose of a laptop. conditions such as those could lead to heat build up and the issues you have seen.
If you are confident enough to do the repair yourself then you can keep your repair costs to a minimum and replace the inverter.
Aug 08, 2009 | Computers & Internet
My screen light just turned off, but i can barely see my desktop and the taskbar. what happened?
sounds like either the ccfl tube died or your inverter died, a easy way to test this is to take a old working laptop, remove the screen bezel on both laptops and dissconnect the plug leading to the screen (usally a pink and white wire cable and connect the cable from the hp to the inverter on the old laptop, power on both laptops and if the hp screen lights up then the inverter on your hp is dead, this is not uncommon on laptops and if you ever get a new laptop try to get one with led backlight technology, if the inverter from the old laptop has the same plugs, put it into the hp, otherwise order a new on
Jun 14, 2009 | HP Pavilion dv7-1130us laptop
Amilo Pro V2010 base removal
Hi
The inverter is in the laptop screen, not the base.
1 remove the screw covers and then the screws surrounding the laptop screen
2 gently prise the screen bezel away from the screen, best done when the laptop is opened out almost flat
3 the inverter is at the base of the screen, gently unscrew and unclip the inverter from the LCD screen
4 take replacing the inverter to make sure all the leads are safely housed
5 replace screen bezel and away you go
Oct 11, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
