Question about Black & Decker CCS818 Chain Saw
Chain adjuster I have a Black & Decker GK1640T Chain Saw but there does not appear to be any chain adjuster. I suspect its a screw which has fell out and maybe its housing but stockists are asking which type machine it is type 1 2 3 4 or 5? I cannot see this marked anywhere.
    Sergeant:
  • 458 Answers
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: how do you get the safety lock off the chain saw
No repy to clarification.
Posted on Feb 18, 2010
dontbother10
  • 2220 Answers
SOURCE: instructions on black and decker gk1635t electric
Your OM follows:
http://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gk1630t,%201640t_gb_md09.pdf
See page 10 please.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
  • 252 Answers
SOURCE: I do not have a
You should be able to remove the cover at the adjustment screw..........First back the screw out at about half way....then remove 2 nuts remove cover........Pull blade ....it should slide with chain attached to snug chain ....Then reinstall cover and nuts and re adjust....This is how mine is done but you have to remove cover to loosen blade so you can slide it to tighten chain and reset the adjustment screw...................Hope this helps...............................Metalpoet
Posted on Mar 08, 2011
Testimonial: "Your suggestions worked, thank you.. I love my little saw; never that a problem with it...It is great for trimming small branches and brushes "
jyackle5
  • 8197 Answers
SOURCE: We require a manual for
You can get the manual on the link below.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
Posted on Apr 20, 2011
How to tighten chain on black and decker cordless pole saw
A properly-tensioned chainsaw chain should still be just a little loose on the chainsaw guide bar, but the chain needs to be tight enough that you can't pull the drive links out of the bar nose.
More details how to tighten the chain on black and decker cordless pole saw go to the link Practical Black and Decker Pole Saw Review
Jul 21, 2013 | Black & Decker Black Decker NPP2018B 18...
I need a manual for Black and Decker Chain saw DN302
Usually any hi lo adjustments are close to the same for any chainsaw if you can't find it
Mar 20, 2012 | Garden
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
I do not have a manual.... I can't adjust the tension. It looks like I have too much chain, the screw is as tight as I can get it. Help!! I have a Cordless Chain Saw, model CCS818 TYPE 1.
the bar should also raise and lower when you apply tension onto the blade - one way or the other it shoudl allow you to tighten the blade.,.. If it is still loose after that, you may be more safe to grab a new blade if this is from wear or use.
Also another fyi: If you get these blades hot and too tight, when they cool, they can warp your bar... I always loosen the chain on mine (per owners manual) immediately after use so it will not do any damage when it cools down..
Did you try to find an owners manual at black and decker dot com?
Best regards
Ck
Mar 08, 2011 | Black & Decker CCS818 Chain Saw
I cannot find my manual to my 18v cordless chainsaw ccs818. I need directions for putting the chain back on. I would like to download a copy of the manual.
Your manual can be found here:
http://www.blackanddecker.com/Manuals.aspx with pop-ups enabled then enter your model number
or
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
See the instructions for replacing the chain on page 11. It makes reference to the figures on page 6 so that you know exactly what to remove.
Basically... loosen the bar allen screws. Remove the sprocket cover. Loosen the bar retaining bolts. Use a flat bladed screwdriver on the bar / chain tension screw to shorten the bar enough to install the chain. Then adjust the chain tensioner so that there is just a little slack in the chain at the bottom of bar between the drive sprocket and the bar. Tighten the bar retaining bolts install the cover / tighten all cover fasteners. (see details D and E page 6 of the 2nd link above.)
The steps below are copied from the manual.... I can not undo the formatting and can not post the figures here due to size restrictions..
Thanks for choosing FixYa,
Kelly
Replacing the Saw Chain
CAUTION: Sharp chain. Always wear protective gloves when
handling the chain. The chain is sharp and can cut you when it is
not running.
WARNING: Sharp moving chain. To prevent accidental
operation, insure that battery is disconnected from the tool
before performing the following operations. Failure to do this
could result in serious personal injury.
• Place the saw on a firm surface. Rotate the two allen head screws
(11) counterclockwise with the wrench (13) provided as shown in
figure E.
• To remove the saw chain (9), rotate the tension adjustment screw
(23) in the front of the housing using the flat screwdriver end of the
wrench (13) as shown in figure F. Turning the screw
counterclockwise allows the guide bar to recede and reduces the
tension on the chain so that it may be removed.
• Remove sprocket cover (10) and allen head screws (11).
• Lift the worn saw chain (9) out of the groove in the guide bar (8).
• Place new chain in groove of guide bar making sure saw teeth are
facing correct direction by matching arrow on chain with graphic on
housing shown in figure G.
• Place the saw chain and guide bar assembly around the sprocket
(19). Check to make sure that the slot (20) in the guide bar (8) is
over the two location pins (21) shown in figure E and that the hole
below the slot is located over the adjustment pin (22).
• Replace sprocket cover (10) and thread allen head screws (11) in
with wrench until snug, then back wrench off one full turn.
• Pull bar nose up and keep it up as you adjust tension.
• Rotate the tension adjustment screw (23) in the front of the housing
clockwise to increase the chain tension as in Figure F.
Follow instructions in "Adjusting Chain Tension" section.
• While still holding the bar nose up, securely tighten the rear allen
screw (11) first, then tighten the front allen screw.
• When the chain is new check the tension frequently (after
disconnecting battery) during the first 2 hours of use as a new chain
stretches slightly.
not running.
• With the saw still on a firm surface check the chain tension. The
tension is correct when the chain snaps back after being pulled
1/8 inch (3mm) away from the guide bar (8) with light force from the
middle finger and thumb as shown in figure H. There should be no
"sag" between the guide bar and the chain on the underside as
shown in figure I.
• To adjust saw chain tension, loosen the allen head screws (11).
using the flat screwdriver end of the wrench (13) as shown in
figure F.
• Do not over-tension the chain as this will lead to excessive wear
and will reduce the life of the bar and chain. Overtensioning also
reduces the amount of cuts you will get per battery charge.
• Once chain tension is correct, tighten allen head screws (11).
stretches slightly.
Nov 08, 2010 | Black & Decker Garden
How do you adjust the tension in the black and decker 16 inch electric chain saw. The chain is too loose...
UNPLUG THE CHAINSAW. if it's got a bolt or two on the right hand side loosen them, then turn the adjuster screw next to the bar until you have about 1/4 inch slack in the chain. tighten nut/nuts. if it's got tool-less adjustment loosen the cover bolt, turn the tensioner, tighten the cover bolt.
Mar 28, 2010 | Garden
Chain fell off chain saw remington 10" pole saw, need directions to put back on.
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Sep 26, 2009 | Remington Electric Pole Saw
Black & Decker CCS818 Chain Saw Logo
299 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
