Question about FUJIFILM A170 Digital Camera
I can't open my camera
1 year not using it .now I can't open even using new batteries
    Problem Solver:
  • 14 Answers
If you left batteries in the camera...chances are they have leaked and now are corroded. The only thing that I can suggest is you take a very small flat tip screwdriver and try to pop it open. Be very careful not to set the camera on your lap while doing this, you'll want to set it on a hard smooth surface, and in case the batteries are leaking put the camera on a plastic bag.
Posted on Apr 16, 2014
I have a Canon PowerShot A530 camera which is around 4 years old. till recently it was working great but from last 3 months, it is giving false indication of low batteries and shuts down. Even after full...
if you are using this camera for 4 yrs with the same lithium battery then you might need to try a new battery
any lithium battery cell's capacity diminishes after long use. it reduces the cell's ability to deliver current. the older batteries do not charge as much as new one.
when you charge your battery it irreversibly loses approximately 20% capacity per year.
hope this help
Sep 08, 2010 | Cameras
Camera won't stay on, even with new batteries that I know are charged.
Ensure you are using alkaline batteries and that battery contacts have no oxide or liquid on top of them. If you do not use alkaline batteries this is normal.
If batteries are ok is a short circuit.
Jul 29, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
I have a Canon A590 Low Battery even with new batteries installed
Use NMH type batteries standard batteries are not good enough for the write load that this camera draws. I think it recomjmends this in your manual if you still have it.
also dont use rechargables
Please rate my help++++Thyanks for using FIXYA
May 09, 2010 | Canon PowerShot A590 IS Digital Camera
Camera Kodak C713 does not turn on..even on trying new batteries..It is 1 year old..
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EasyShare C713 Digital Camera
Sony Mavica MVC-CD400 will not operate under battery power.
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Aug 31, 2009 | Sony Mavica MVC-CD400 Digital Camera
Canon a570 battery fail - with any and all new batteries
Hmmm...... there might be a time battery that needs replacing. Look fore something like CR1220 or time battery. Pry it open and replace it with a battery of the same size.
Jan 05, 2009 | Canon PowerShot A570 IS Digital Camera
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
Low battery warning
It's something with the camera. I have the same camera and the same problem. I bought 2 brand new batteries, charged them, and the very first thing the camera did when I installed the new batteries was tell me that they were dead!! Grrr....
As a workaround, when it tells you the battery is dead, just open the battery door, close it, and try again. Repeat if necessary. With my camera, doing this lets me use the same battery for days and days. The battery is NOT dead - it's just a faulty warning message.
Apr 18, 2008 | Canon PowerShot SD10 / IXUS I Digital...
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
FUJIFILM A170 Digital Camera Logo
27 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
