Question about NEC Televison & Video
Television keeps turning off when it is turned on
    Top Expert:
  • NEC Master
  • 74,887 Answers
Short circuited component/s at its main board. Contact any service technician. Gopakumar Gopalan Google
Posted on Apr 14, 2014
My 32" G.E. television can
I have had similar experiences. I have a VCR sitting near the television. I found that if I keep the VCR turned on then the TV stops changing channels by itself. If the VCR is turned off, then it starts again. Weird, but it worked for some reason.
Feb 15, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Television keeps losing its picture quality and turns itself off.
your T-Con board is failing you need a tech to replace it
Nov 18, 2009 | Televison & Video
My tv keeps shutting on and off
You television is having problems with intermittent component failure. The reason the television turns off and on is the protection circuit turns on when it senses high voltage or current level that may damage the internal circuits. The protection circuit turn the television off, the television will stay in this condition until the faulty component or components temporarily stabilize. When this happens the television attempts to turn itself on again. Once the component or components heats up it loses tolerances and again triggers the protection circuit to turn the television off. This is a problem that should be fully tested and evaluated by a certified service center. You can contact RCA customer support at this telephone number 1-877-947-7977 between the hours of 8am-8pm M-F EST and. 10am-7PM S/S EST. You can also contact RCA customer support on line at this web page link http://tv.rca.com/en-us/ContactUs.html I hope this information help you solve your problems with the television. Thank you for using FixYa and have a nice day!
Jun 20, 2009 | RCA R52WM24 52" HDTV Projection Television
Can't turn on television two red lights on television
Make sure that all of the access doors are properly closed. There are interlocks there that will prevent the set from working if the door is open. Also, check to be sure that the fans turn freely and are clear of debris.
Please keep us updated on progress.
Thanks,
Dan
May 30, 2009 | Epson Livingstation LS57P2 57" Rear...
My Insignia tv keeps defauting to Video1 screen every minute!!!
Turn off your television. Try disconnecting all external signal sources (except the antenna or cable) from your television.Turn on the television and see if this resolves the problem. If it does then you may have a faulty cable connection to your television. Change out the cables one by one to find the bad cable and replace it. If this does not solve your problem. Turn off for a period of hours(This may allow your television set to reset itself) and test again. If you still have the same problem, Then you need to call customer service for servicing and technical advise. Call this number for service : 1-877-467-4289. Hope this helps you with your problem.
Apr 07, 2009 | Insignia LCDTV26 26 in. Television
RCA HD50LPW175
Hi my tv is having problems it wont come on went i turn on  my tv the light flash like five time and they turn off again i already replace the lamp because it was bad the other one but i try to turn it on again a keep doing the same flashin g five time and it turn off it self please help me i already pay a idiot to check it out and he told me i was the lamp i replace it but it keep doing the same i dont want the same idiot to come and said another stufff and i keep spending money
Apr 03, 2008 | RCA HD50LPW175 50" HDTV
My tv keeps shuttinf off
does the picture ever come up?...the processor on this set shuts down the set when there is a problem. then generates an error code log. a tech should be able to read these to help determine the problem
Nov 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Television keeps turning itself off.
There are two integrated circuits called convergence amplifiers , they need to be replaced. this is a common failure on this model. the cost to replace with parts is around 250.00 dls depending on the tech. if you need more help let know thanks
Jun 14, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
