Question about Kitchen Ranges
My 1991 ford pick up straight 6 fuel injection ran out of gas
Truck been parked for two years was in good condition brought it from someone gas gauge didnt work put gas in ran out switched tanks promblem began
SOURCE: fuel gauges no working 1989 ford f-150
drop the gas tank and either replace the fuel sending unit connected to the fuel pump, or you can try to clean the contacts w/ a pencil eraser, just be gentle
Posted on Mar 13, 2009
csmock132
  • 4669 Answers
SOURCE: 1987 GMC sierra , no fuel pump power.
The inline fuel pump fuse on the passenger side firewall is good? Are you jumping it with 12 volts at the test lead or the fuse?
Posted on Jun 26, 2009
SOURCE: fuel gauge not working
Unplug the transfer switch from the dash and clean the contacts. I had a similar problem. rh tank would go max full. works fine now
Posted on Jul 29, 2009
ftw1952
  • 10319 Answers
SOURCE: I have a 1988 Ford F250 with the 460 engine and
The fuel pump relay and the oil pressure switch as well. The oil pressure switch runs power to the fuel pump when you first start it
When the oil pressure reaches operating range the relay takes over
They are both inexpensive so replace both of these parts to be safe and kill two birds with one stone. If one goes out the other will soon enough
Posted on Mar 27, 2010
  • 14 Answers
SOURCE: Why is gas gauge not working correctly since fuelpump was replaced.
Is this a flex fuel vehicle. If so, call the dealership and ask the parts dept. if there is a gauge module (perhaps behind the instrument cluster). This may be the culprit and needs to be replaced.
Posted on Oct 10, 2012
Ran out of gas switched tanks promblem began
Sounds like fuel filter could be stopped up.
Apr 14, 2014 | 1991 Ford F150
Ran out of gas
Probably 2 year old gas in other tank. switch back to the good tank and run injector cleaner for at least 2 tanks of gas.
1991 f150 ford pick up think mite got trash in fuel injection
If you have dual fuel tanks there is usually another fuel filter on the frame under the drivers position under the truck. If this is the problem the truck will hesitate when you press on the gas pedal to pass someone.
Apr 04, 2014 | Ford Explorer Cars & Trucks
Fuel injection v 6ford 1991
I would replace the fuel filer first
Apr 03, 2014 | Ford F-150 Cars & Trucks
Ran out of gas in my 95 toyota camry put 30 dollars of gas in it then it would not start. replaced fuel pump put seafoam in gas, new spsrk plugs, starts and idles but when I put it in gear and press the...
which engine options, surely you know it? to fix it you must.
ran it out of gas, car ran perfect or it was found with no gas
and im trying to bring bad a log parked car..... history , context....
was this car a daily driver, last month>?
seaform is junk never use that , never use additives unless pure raw
desperation, tell me ,why do mfg ,void your warranty with this in anycar, there is only 1 answer to that....
and why risk 4 poison 02 sensors on a V6, (worst case)
huh?
ok, engine stalls. (can a fast right foot save the stall)?
if compression is good.
and 12vdc is at the EFI , system. no below 10v ever.
then check for spark loss. on all cylinders? good?
did you scramble the spark wire? they have a firing order?
did you?
does car start and run good and sound good on test fuel (spray)
these answer bring us to fueling last.
injections.
all EFI systems cut fueling if
  1. spark seems weak.
  2. CMP errors
  3. CKP errros
  4. or IMMO is unhappy. (lamp says, im unhappy, injection is CUT0
let us know, what you find.
and a fuel gauge tells you if fuel pressure meets spec.
and the injectors dont leak and a balance test show they are equal
all with one simple $20 gauge.
a $2 NOID lamp test the injector pulse.
Feb 17, 2014 | 1995 Toyota Camry
Ran out of fuel put some fuel in gas tank but still wont start
Try removing fuel filter, empty it and clean, try again, sometimes loose particals from bottom of tank may be picked up when ran dry
Jan 28, 2013 | 1991 Ford F150
I have a 1991 ford f150 6cyl. when I give it a light gas its runs ok, but if I give it a hard gas it seem to bogg down and shake, sputter. why is it doing this? I did change the fuel filter and still...
Ahhh. you have one of the first verisions of fuel injection... check all your vacuum lines, had a 89 ford f-150 I-6 with a similar problem years back. did everything from change vieciel speed sensor to the oxygen sensor... it was a tiny leak in vacuum line... Good luck!!
Feb 24, 2012 | 1991 Ford F150
I have a 1991 Park Avenue. Only four cylinders fire.
Test the compression on the two cylinders that won't fire. Make sure their plug wiring is not crossed. Check those two spark plugs after running a short time--they should be wet with fuel if not firing. Any injector that won't stop leaking should be replaced. Fuses and relays should not be responsible for just two cylinders not running. The check engine light should be on--read the computer with a scanner. An engine with two cylinders inoperative SHOULD vibrate heavily. Good luck!
Feb 09, 2010 | 1991 Buick Park Avenue
Quits like fuel pump goes out but has good fuel pres new delco
i had the same problem and it died out of town got it towed and it was the fuel pump fuse and that was it they are famose for it
Jul 05, 2009 | 1991 Chevrolet Cavalier
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
